Popular Post ricktendo Posted October 12, 2012 Popular Post Share Posted October 12, 2012 Quote About: These packages contain .NET Framework 4.6.1 Full x86/x64 installers including updates (and Language Packs) integrated. For command-line options run <installer_name>.exe /? Note: The reason its called "Slim" is because the original MSI installers have been carefully edited to remove unnecessary setup junk, this should save 200+ MB of space on your HDD/SSD. OS: Windows Vista/Server 2008 SP2 x86/x64 or Windows 7/Server 2008 R2 SP1 x86/x64 Slim Microsoft .NET Framework 4.6.1 Full x86/x64 Slim Microsoft .NET Framework 4.6.1 Full x86/x64 Incl. Language Packs (ar cs da de el es fi fr he hu it ja ko nl no pl pt-BR pt-PT ru sv tr zh-Hans zh-Hant) Some tools and resources for (re)creating your own slim (intl) installer .NET4.6.1 SFX Maker (installer repacker): .NET4.6.1 Intl SFX Maker (if you want to add LP): Silent "No GUI" SFX alternative: Slim down your dotNET4(.6.x) & LP installers: If you cant find a hotfix try using the KB(1234567) number w/ this URL: Slim Language Packs: Arabic: N/A Chinese (Simplified): Chinese (Traditional): Czech: Danish: Dutch: Finnish: French: German: Greek: Hebrew: Hungarian: Italian: Japanese: Korean: Norwegian (Bokmal): Polish: Portuguese (Brazil): Portuguese (Portugal): Russian: Spanish: Swedish: Turkish: http://support2.microsoft.com/hotfix/KBHotfix.aspx?kbnum=1234567 akuiraz, filter, remzkee0903 and 54 others 57 Quote Link to comment Share on other sites More sharing options...
dareckibmw Posted October 13, 2012 Share Posted October 13, 2012 Already tested it in vmware, works good.Thanks Rick! Quote Link to comment Share on other sites More sharing options...
yogurt Posted October 13, 2012 Share Posted October 13, 2012 (edited) Thanks Rick, I am going to wait for the Silent "No GUI" SFX alternative v1, so i can repack it for use with DXI. Edited October 13, 2012 by dotfusion Quote Link to comment Share on other sites More sharing options...
ricktendo Posted October 13, 2012 Author Share Posted October 13, 2012 I am going to wait for the Silent "No GUI" SFX alternative v1, so i can repack it for use with DXI.Done, tomorrow will see if I can do the LP's Quote Link to comment Share on other sites More sharing options...
bphlpt Posted October 13, 2012 Share Posted October 13, 2012 Rick, your dropbox link: (Integrate this (before you slim) to activate/enable LDR/QFE branch:) is a dead end.Cheers and Regards Quote Link to comment Share on other sites More sharing options...
ricktendo Posted October 13, 2012 Author Share Posted October 13, 2012 Rick, your dropbox link: (Integrate this (before you slim) to activate/enable LDR/QFE branch:) is a dead end.Fixed, aparently DropBox does not like "Read Only" attribsEdit: Just noticed there is a new .net4.5 installer available, did a refresh using the new installer. plz redownloadNote: The .NET Framework 4.5 redistributable was updated on 10/9/2012 to correct an issue related to an improper timestamp on a digital certificate which causes the digital signature on files produced and signed by Microsoft to expire prematurely. We recommend customers that previously installed the .NET 4.5 redistributable package dated 8/16/2012 install this updated .NET 4.5 redistributable package. More information about the issue can be found Microsoft Security Advisory 2749655.Edit2: All Language Pack links are now live (yes I did use the refreshed LP installers) Quote Link to comment Share on other sites More sharing options...
yogurt Posted October 13, 2012 Share Posted October 13, 2012 Rick, I want to repack this for a silent install using the alternate method, But i not clear on what you mean byIntegrate this (before you slim) to activate/enable LDR/QFE branch:http://adf.ly/1713566/kb2519265Do you mean to integrate to my media, or to integrate it to my repack?Do I understand this right?1. unpack your slim insaller in a folder2. add NDP45-KB2519265 to same folder3. 7 zip the whole thing4. drop the archive on your repack script Quote Link to comment Share on other sites More sharing options...
RicaNeaga Posted October 13, 2012 Share Posted October 13, 2012 Thank you again Rick for an amazing installer.However, I do have a question: I see that Microsoft is looking at .net 4.5 from two perspectives - the same problem generates two very different hotfixes, one for vista and 7, and one for 8 and 8 RT. So in this case wouldn't it be recommended to make two separate installers, one for pre-windows 8 OSes, and one for 8? For example, what versions of clrjit.dll and peverify.dll does your installer contain? Quote Link to comment Share on other sites More sharing options...
ricktendo Posted October 13, 2012 Author Share Posted October 13, 2012 @dotfusion My installer already has KB2519265, this is there only for people who want to make (from scratch) a similar installer. I provide the script to slim, KB2519265 to enable LDR hotfix integration, etc, but you dont need to worry about KB2519265Just extract my installer (or use 7zsplit to get the 7zip,) add a LP (optional,) use the SFX maker and/or No GUI to rebuild the executable by dragging & dropping the 7z onto the cmd (first editing config.txt to enable LangPack if you added one or to enable the reg add lines that will allow you to install during setup)@RicaNeaga Windows 8 does not need a installer, you just integrate the update with dismBTW my installer has KB2519265 applied so the LDR branch is always used Quote Link to comment Share on other sites More sharing options...
RicaNeaga Posted October 13, 2012 Share Posted October 13, 2012 Oh, great, thanks for the clarification. I'm not very into windows 8 right now, but it's nice to know for the future. So this installer is only for windows 7 & vista - maybe it's a good idea to bold that text in the first post, so some users with windows 8 won't use this. Quote Link to comment Share on other sites More sharing options...
ricktendo Posted October 27, 2012 Author Share Posted October 27, 2012 Add: 2756203 Quote Link to comment Share on other sites More sharing options...
Gabee Posted October 28, 2012 Share Posted October 28, 2012 Hello!Great work!How to slipstream this pack for Vista and Windows 7? Quote Link to comment Share on other sites More sharing options...
laddanator Posted October 28, 2012 Share Posted October 28, 2012 Using this today for the first time with the /y command but installation stops and says the computer needs to be rebooted yes or no if you plan to reboot later. Have I missed something? A no reboot command? Quote Link to comment Share on other sites More sharing options...
yogurt Posted October 30, 2012 Share Posted October 30, 2012 Hello!Great work!How to slipstream this pack for Vista and Windows 7?You could always add it under silent installers in Win Tool Kit Quote Link to comment Share on other sites More sharing options...
mooms Posted October 30, 2012 Share Posted October 30, 2012 If i integrate this, i don't have to integrate 4.0 anymore isn't it ? Quote Link to comment Share on other sites More sharing options...
ricktendo Posted October 30, 2012 Author Share Posted October 30, 2012 If i integrate this, i don't have to integrate 4.0 anymore isn't it ?Correct, 4.5 replaces it. 4.0 is only still around for XP users Quote Link to comment Share on other sites More sharing options...
alfreire Posted November 1, 2012 Share Posted November 1, 2012 Thank you very much...Muchas gracias compañero, por esto y por mucho más... :beerchug:Regards... ;-)SaluII... ;-) Quote Link to comment Share on other sites More sharing options...
mooms Posted November 2, 2012 Share Posted November 2, 2012 +1 Thanks Ricktendo64 Quote Link to comment Share on other sites More sharing options...
Forseti Posted November 13, 2012 Share Posted November 13, 2012 @ RicardoKB2737083 is out now! Quote Link to comment Share on other sites More sharing options...
ricktendo Posted November 13, 2012 Author Share Posted November 13, 2012 Way ahead of ya11-13-2012Add: 2737083Upd: SFX (removed /ain)BTW I removed /ain switch, because I noticed by default the installer runs ngen so I see no need in running it twice Quote Link to comment Share on other sites More sharing options...
parapher Posted November 14, 2012 Share Posted November 14, 2012 (edited) BTW I removed /ain switch, because I noticed by default the installer runs ngen so I see no need in running it twiceThanks for the info. I have one question about the 4.5 .NET: with the .NET 4 you provided a way to install Client or Extended, does this not apply to .NET 4.5? Thank you. Edited November 14, 2012 by parapher Quote Link to comment Share on other sites More sharing options...
Forseti Posted November 14, 2012 Share Posted November 14, 2012 Thank You Ricardo! Quote Link to comment Share on other sites More sharing options...
ricktendo Posted November 14, 2012 Author Share Posted November 14, 2012 Thanks for the info. I have one question about the 4.5 .NET: with the .NET 4 you provided a way to install Client or Extended, does this not apply to .NET 4.5? Thank you.Not any more, Microsoft merged them both into one installer (I see no switches or tricks that I could add to only install client) parapher 1 Quote Link to comment Share on other sites More sharing options...
ricktendo Posted November 16, 2012 Author Share Posted November 16, 2012 11-16-2012Add: 2777291 ZEUS__, dareckibmw and parapher 3 Quote Link to comment Share on other sites More sharing options...
click-click Posted November 27, 2012 Share Posted November 27, 2012 What's the difference between this installer and the rebuilt one that has been patched?.Does this installer not work? Quote Link to comment Share on other sites More sharing options...
