ricktendo Posted June 15, 2013 Share Posted June 15, 2013 Silent install: /qn (and/or other standard MSI switches, custom settings/options switches listed bellow) New: Supported command line switches to add serial number, change installation directory, enable/disable shortcuts, automatic updates, etc. during silent or gui install ;;; To add your serial number SERIALNUMBER=12345-12345-12345-12345-12345 ;;; To change installation directory INSTALLDIR=<directory> ;;; Add =1 to enable or =0 to disable the following (their <default> state is listed) DESKTOP_SHORTCUT=<disabled> QUICKLAUNCH_SHORTCUT=<disabled> STARTMENU_SHORTCUT=<enabled> AUTOSOFTWAREUPDATE=<disabled> COMPONENTDOWNLOAD=<enabled> DATACOLLECTION=<disabled> Example: If you want to automatically install with serial number and re-enable desktop shortcut & automatic updates <vmware-lite>.msi SERIALNUMBER=12345-12345-12345-12345-12345 DESKTOP_SHORTCUT=1 AUTOSOFTWAREUPDATE=1 /qn Optional: Version 11 no longer supports x86 so for 32 bit OS's you need to use version 10: http://adf.ly/1713566/vmwareliteold Or you may prefer VirtualBox Lite MD5: 4680873df8556af936fae393e471fbe2 Size: 70.3 MB kalilou, SirLurksAlot, urie and 6 others 9 Quote Link to comment Share on other sites More sharing options...
bphlpt Posted June 16, 2013 Share Posted June 16, 2013 Thanks Rick! Cheers and Regards Quote Link to comment Share on other sites More sharing options...
ricktendo Posted June 16, 2013 Author Share Posted June 16, 2013 Let me know if it works fine or if anything is broken Quote Link to comment Share on other sites More sharing options...
bphlpt Posted June 16, 2013 Share Posted June 16, 2013 I've asked a couple of more experienced buddies of mine to check it out. I'll let you know when I hear back. Cheers and Regards Quote Link to comment Share on other sites More sharing options...
ricktendo Posted June 16, 2013 Author Share Posted June 16, 2013 Updated, fixed iso tools uninstall (it was broken because I had added "Lite" to the ProductName MSI property) Quote Link to comment Share on other sites More sharing options...
alfreire Posted June 16, 2013 Share Posted June 16, 2013 Thank's Ricardo, I will try... one question, what have you removed ...?Regards... ;-) Quote Link to comment Share on other sites More sharing options...
ricktendo Posted June 16, 2013 Author Share Posted June 16, 2013 VMware Tray, VIX, OVF, Visual Studio, VMware Converter redist, vc runtimes redist, all Tools exept Windows iso, Japanese and German Thin Print localizations, Japanese EULA & help files and a few other misc files (I was too tired to make a list yesterday, but I will soon) alfreire 1 Quote Link to comment Share on other sites More sharing options...
Uncle_Gadget Posted June 17, 2013 Share Posted June 17, 2013 Fantastic, Rick! I'm looking forward to giving it a test drive later this week. Quote Link to comment Share on other sites More sharing options...
ricktendo Posted June 18, 2013 Author Share Posted June 18, 2013 OK seems there may be a problem with me removing SSL, I thought if you had them installed there would be no problem (added them back) Quote Link to comment Share on other sites More sharing options...
alfreire Posted June 18, 2013 Share Posted June 18, 2013 (edited) For now, works perfect... :cap:Regards... ;-) Edited June 18, 2013 by alfreire Quote Link to comment Share on other sites More sharing options...
ricktendo Posted July 1, 2013 Author Share Posted July 1, 2013 Updated SFX and installer. There is no longer need to repack the installer (but you still have the option,) you can now use SERIALNUMBER and other commands to change the default installer behavior. Also added /nsr switch a.k.a. /noSilentReboot to stop reboot during silent install (just in case) Quote Link to comment Share on other sites More sharing options...
boooggy Posted July 5, 2013 Share Posted July 5, 2013 works purfect here tooo Quote Link to comment Share on other sites More sharing options...
alfreire Posted September 4, 2013 Share Posted September 4, 2013 Thanks again... ;-) Quote Link to comment Share on other sites More sharing options...
HJSC Posted September 5, 2013 Share Posted September 5, 2013 Rick is as always doing a great work =)Thanks Quote Link to comment Share on other sites More sharing options...
urie Posted September 5, 2013 Share Posted September 5, 2013 Thanks Rick, any possibility you could make a tutorial on how to make VMWare lite version ? I thought there was one on the forum for older versions but I can't seem to find it. Quote Link to comment Share on other sites More sharing options...
user_hidden Posted September 5, 2013 Share Posted September 5, 2013 thanks Rick appreciated the hard work Quote Link to comment Share on other sites More sharing options...
oguz Posted September 5, 2013 Share Posted September 5, 2013 Perfect job Thanks @rick Quote Link to comment Share on other sites More sharing options...
oguz Posted October 25, 2013 Share Posted October 25, 2013 VMware Workstation 10.0.1 Build 1379776 is released Quote Link to comment Share on other sites More sharing options...
alfreire Posted October 25, 2013 Share Posted October 25, 2013 Gracias, amigo... ;-) Quote Link to comment Share on other sites More sharing options...
NaJeEb303 Posted January 25, 2014 Share Posted January 25, 2014 (edited) hey rick.., d0nt know why, but your sfx maker is n0t creating a w0rking setup f0r me, i just properly foll0wed the steps and inserted the serial number in the bootstrap.lua and hide the serial input dialog of setup by replacing the 0 with 1, and created the final setup, but when i run this setup, nothing happens but the following path is opened: C:\Windows\System32\Setup., i d0nt know whats wr0ng with this, the pr0cedure is simple and i'm pretty sure that i'm not d0ing anything wr0ng..plx heLp...!! :help: Edited January 25, 2014 by NaJeEb303 Quote Link to comment Share on other sites More sharing options...
ricktendo Posted January 25, 2014 Author Share Posted January 25, 2014 What version of 7zip did you use to re-compress and what format? (LZMA/LZMA2)You could try adding .exe to the setup command in config.txt RunProgram="setup.exe /T \"%%T\\install\" /S \"%%T\" /v "AutoInstall="setup.exe /T \"%%T\\install\" /S \"%%T\" /s /nsr /v " Quote Link to comment Share on other sites More sharing options...
NaJeEb303 Posted January 25, 2014 Share Posted January 25, 2014 What version of 7zip did you use to re-compress and what format? (LZMA/LZMA2)You could try adding .exe to the setup command in config.txt RunProgram="setup.exe /T \"%%T\\install\" /S \"%%T\" /v "AutoInstall="setup.exe /T \"%%T\\install\" /S \"%%T\" /s /nsr /v "i used the latest version of 7-zip (9.20) and used the LZMA format..!! Quote Link to comment Share on other sites More sharing options...
ricktendo Posted January 25, 2014 Author Share Posted January 25, 2014 I think whats going on is the sfx cannot find setup (executable) so its launching the \setup folder in system32 (PATH). Adding .EXE will force it to ONLY look for the executable and it will error if not found. Make sure you are compressing the files and not the folder with the files Quote Link to comment Share on other sites More sharing options...
NaJeEb303 Posted January 26, 2014 Share Posted January 26, 2014 I think whats going on is the sfx cannot find setup (executable) so its launching the \setup folder in system32 (PATH). Adding .EXE will force it to ONLY look for the executable and it will error if not found.Make sure you are compressing the files and not the folder with the filesthanx rick.., i was actually compressing the folder with the files.., now it w0rked after compressing the files.., and i was already in doubt with that...!!thanx..!! Quote Link to comment Share on other sites More sharing options...
jgp Posted April 18, 2014 Share Posted April 18, 2014 VMware Workstation 10.0.2 Build 1744117 is out alfreire 1 Quote Link to comment Share on other sites More sharing options...
