[Release] Windows XP Post SP3 UpdatePack 1.0.9
Windows XP Post Service Pack 3 UpdatePack
No longer updated... Try this one http://www.ryanvm.net/forum/viewtopic.php?t=6251
MD5: 63560AD484ECF28B197CC29A888A7E06
Credit: UpdatePack is based on the work of the RyanVM UpdatePack, XUDPack by Xable and code65536 UpdatePack AddOn.
Includes:
Adobe Flash Player 9.0.115.0
qfecheck 6.2.29.0
Malicious Software Removal
Microsoft Update 7.0.6000.381
Office Genuine Advantage 1.6.21.0
Office Update Engine 12.0.5525.1000
Windows Genuine Advantage 1.7.59.1
WSUS 3.0
Changelog:
Jauary 12-2008
v1.0.9
- Fixed typo in my entries.ini (sorry guys)
Jauary 12-2008
v1.0.8
- Updated MRT
December 22-2007
v1.0.7
- Updated MRT
December 06-2007
v1.0.6
- Updated Flash 9.0.115.0
- Fixed MU ActiveX Run prompt
November 24-2007
v1.0.5
- Updated MRT
October 10-2007
v1.0.4
- Un-Stubbed MRT (resulting in a bigger filesize)
October 10-2007
v1.0.3
- Updated WGA 1.7.59.0
- Updated MRT October
October 8-2007
v1.0.2
- Updated Microsoft Update 7.0.6000.381
- Stubbed the Malicious Software Removal Tool (version: 1.32 by code65536)
  • Replies 89
  • Views 47.1k
Thanks Rick...I'll be the same as Kel....... :whistle:
Rick can you please update because the dl is not running..it stucks :huh:
Edited by JurgenDoe
can i addthis over ryans update pack?and how come ure addon is so small?the original sp3 size is 300+mbs(i know that it contains more files,as ure addon prolly only has critical hotfixes,but so does ryan's,and his is prety big).
Rick I've send you a PM :whistle:
Please don't post such posts, since it looks like spamming. Also, as soon as you send message to Rick, it will pop-up on his screen when he refreshes or opens a new page on the forum. :icon_rolleyes:
No hard feelings, we just want to have this board as clean as possible.
Cheers..
Hello. . I've been contemplating adding sp3 Pre beta to my disk but heres the things stopping me, if anyone can say otherwise just for the benifit of others, then please do.
1.SP3 may have a time bomb hidden to stop XP eventually.
2.The keys ment for SP2 may fail to work with SP3.
3.MS Updates may fail because SP3 is detected.
4.When the final SP3 comes out it wont allow you to apply it to the system if the Pre SP3 is detected.
So the main concerns here are the future proofing. . . I've put alot of time into my disk and it means I somtimes don't see PC's back for years. . so knowing it's safe for updates is most important.
Rick, I know it's just a project/hobby/test this update pack. . . but please consider NOT doing it, you time is to valuable to waste on this project. . about 1/2 my Disk mods are your's, so keep up the good work, but don't extend this Post SP3 Pre BETA update pack to more than a learning experiance, cause I don't see it mattering in a few months when final appears.
Sorry if I sound disrespectful, but I've spent my share of wasted time on projects like this, so think of it more as advice.
RON
Yea you are correct... Some keys are invalidated with the Pre Beta SP3.
BTW the official SP3 Beta will be released by MS sometime this week, lets see if this is better that the leaked version.
