ricktendo Posted October 28, 2006 Share Posted October 28, 2006 (edited) AveIconifier2 by AndreasVMD5: 1660EC5987E743B95BAFBF30205CFB2FSize: 402 KBWebsite: http://www.aqua-soft.org/board/showthread.php?t=15304Installs shortcut to Start->All Program->Utilities.Features- Convert ICO to PNG and vice versa.- Simple drag-'n-drop interface.- Totally skinnable application.- Right click on the captionbar to select a skin.- Select output formats for icons (right click on the icon pane).What's new?- Multi Icons are now created from PNGs: 16x16, 24x24, 32x32, 48x48, 64x64, 72*72 96x96, 128x128 are possible. All 32bits.- Converts faster- Batch converting, just drag multiple icons/pngs to the pane.- Any PNG size is now supported.- Luna skins included and made default.How does it work?Drop an ICOn from explorer onto the left pane. Drag it from the right pane into explorer to get an PNG file out of the icon. Vice versa for PNG to ICO.Kudos toLou for the icon and the logo.Altoprofilo for the excellent Luna skins. Edited October 28, 2006 by ricktendo64 Quote Link to comment Share on other sites More sharing options...
Guest beemarin Posted October 28, 2006 Share Posted October 28, 2006 A local version of this would be useful, considering how it can be a pain to continually upload icons to their website. Thanks for the information Quote Link to comment Share on other sites More sharing options...
Guest Posted February 13, 2009 Share Posted February 13, 2009 thank you rick Quote Link to comment Share on other sites More sharing options...
