chymax3m Posted September 18, 2014 Share Posted September 18, 2014 kanyos could you leave the russian language interface in the next versions, that would be great... Quote Link to comment Share on other sites More sharing options...
Dziubek Posted October 12, 2014 Share Posted October 12, 2014 VirtualBox 4.3.18 (released 2014-10-10)This is a maintenance release. The following items were fixed and/or added:VMM: fixed a potential misbehavior after restoring the A20 state from a saved stateGUI: fixed full-screen mode mini-toolbar related regressions for different platforms and window managers (bug #13369)GUI: X11: fixed full-screen mode Unity panels quirk caused by mini-toolbar code changes in last release (bug #13365)GUI: X11: added possibility to use legacy full-screen mode as the new one can cause multi-screen issues under Unity, see the manual for more information (bug #13365)GUI: Mac OS X: fixed full-screen mode artifact causing black screen when 3D acceleration was enabled on 10.10 Yosemite hosts (bug #13448)GUI: Mac OS X: fixed regression in user-space swiping from/to VBox in full-screen modeGUI: Mac OS X: fixed issue with switching to VBox in full-screen mode through Alt+Tab and Mission ControlStorage: fixed data corruption when resizing huge VHD images under certain circumstances (bug #11960)Storage: fixed a rare hang during startup when the BIOS enumerates the storage devices attached to the SATA controllerStorage: follow the spec with AHCI interrupt acknowledge (bug #13474)Storage: fixed broken iSCSI authentication (4.3.14 regression, bugs #13386, #13435)NAT Network: properly parse port forwarding rules to allow UDP rulesUSB: fixed a crash on Linux hosts with older Linux kernels (bug #13400) and several other fixesACPI: fixed ACPI timer anomalies (bug #12076)Guest Control: fixed a memory leak (bug #13434)Main: when removing a VM, do also remove the VBoxStartup.log file which might exist on Windows hosts (bug #13478)Windows hosts: fixed more startup problems on certain Windows hosts due to conflicts with anti-virus software; better error reporting (4.3.14 regression; bug #13187)Windows hosts: propagate the process startup information to the child process (4.3.14 regression; bug #13243)Mac OS X hosts: don't force using the discrete GPU (bug #11111)Windows Additions: some Windows 10 tweaksX11 guests: fix a bug handling video driver display properties which prevented GNOME Shell on Fedora 21 from startingLinux hosts / guests: fixed a few remaining warnings in the kernel log if memory allocation fails (bug #11171) Could you leave the polish language interface and stuff (drivers, etc) for testing Linux distribution in the next versions? alfreire 1 Quote Link to comment Share on other sites More sharing options...
kanyos Posted October 13, 2014 Author Share Posted October 13, 2014 kanyos could you leave the russian language interface in the next versions, that would be great... done. VirtualBox 4.3.18 (released 2014-10-10)This is a maintenance release. The following items were fixed and/or added:VMM: fixed a potential misbehavior after restoring the A20 state from a saved stateGUI: fixed full-screen mode mini-toolbar related regressions for different platforms and window managers (bug #13369)GUI: X11: fixed full-screen mode Unity panels quirk caused by mini-toolbar code changes in last release (bug #13365)GUI: X11: added possibility to use legacy full-screen mode as the new one can cause multi-screen issues under Unity, see the manual for more information (bug #13365)GUI: Mac OS X: fixed full-screen mode artifact causing black screen when 3D acceleration was enabled on 10.10 Yosemite hosts (bug #13448)GUI: Mac OS X: fixed regression in user-space swiping from/to VBox in full-screen modeGUI: Mac OS X: fixed issue with switching to VBox in full-screen mode through Alt+Tab and Mission ControlStorage: fixed data corruption when resizing huge VHD images under certain circumstances (bug #11960)Storage: fixed a rare hang during startup when the BIOS enumerates the storage devices attached to the SATA controllerStorage: follow the spec with AHCI interrupt acknowledge (bug #13474)Storage: fixed broken iSCSI authentication (4.3.14 regression, bugs #13386, #13435)NAT Network: properly parse port forwarding rules to allow UDP rulesUSB: fixed a crash on Linux hosts with older Linux kernels (bug #13400) and several other fixesACPI: fixed ACPI timer anomalies (bug #12076)Guest Control: fixed a memory leak (bug #13434)Main: when removing a VM, do also remove the VBoxStartup.log file which might exist on Windows hosts (bug #13478)Windows hosts: fixed more startup problems on certain Windows hosts due to conflicts with anti-virus software; better error reporting (4.3.14 regression; bug #13187)Windows hosts: propagate the process startup information to the child process (4.3.14 regression; bug #13243)Mac OS X hosts: don't force using the discrete GPU (bug #11111)Windows Additions: some Windows 10 tweaksX11 guests: fix a bug handling video driver display properties which prevented GNOME Shell on Fedora 21 from startingLinux hosts / guests: fixed a few remaining warnings in the kernel log if memory allocation fails (bug #11171) Could you leave the polish language interface and stuff (drivers, etc) for testing Linux distribution in the next versions? done.but, sory, there are no Polish inside main binaries, so i can not include Polish. alfreire 1 Quote Link to comment Share on other sites More sharing options...
Docthal Posted October 13, 2014 Share Posted October 13, 2014 awesome many thanks Quote Link to comment Share on other sites More sharing options...
Dziubek Posted October 13, 2014 Share Posted October 13, 2014 I understand the super thank you :-) Quote Link to comment Share on other sites More sharing options...
kanyos Posted November 22, 2014 Author Share Posted November 22, 2014 new version: 4.3.20 :type: alfreire 1 Quote Link to comment Share on other sites More sharing options...
chymax3m Posted February 13, 2015 Share Posted February 13, 2015 A new version: 4.3.22.98236 Quote Link to comment Share on other sites More sharing options...
kanyos Posted February 14, 2015 Author Share Posted February 14, 2015 A new version: 4.3.22.98236 Nice info :beerchug: Quote Link to comment Share on other sites More sharing options...
kanyos Posted March 3, 2015 Author Share Posted March 3, 2015 updated v4.3.24 alfreire 1 Quote Link to comment Share on other sites More sharing options...
Sh4x Posted March 16, 2015 Share Posted March 16, 2015 Hi, Thank you so much for this! Would it be possible to include French language in future releases? Thanks! Quote Link to comment Share on other sites More sharing options...
kanyos Posted March 18, 2015 Author Share Posted March 18, 2015 Hi, Thank you so much for this! Would it be possible to include French language in future releases? Thanks! done :beerchug: alfreire and Docthal 2 Quote Link to comment Share on other sites More sharing options...
Sh4x Posted May 4, 2015 Share Posted May 4, 2015 (edited) Hi, Thank you so much for this! Would it be possible to include French language in future releases? Thanks! done :beerchug: Awesome, thanks! I'd like to be able to do this myself. Any good tutorials or books you would recommend to learn on this subject? Edited May 4, 2015 by Sh4x Quote Link to comment Share on other sites More sharing options...
chymax3m Posted May 11, 2015 Share Posted May 11, 2015 Can anybody upload a repack of 4.3.12 version somewhere, i just couldn't create a virtual machine using the version 4.3.18 and 4.3.26, met some errors. Searching in the web found out that 4.3.12 was the last "normally working" version. Quote Link to comment Share on other sites More sharing options...
kanyos Posted May 12, 2015 Author Share Posted May 12, 2015 Can anybody upload a repack of 4.3.12 version somewhere, i just couldn't create a virtual machine using the version 4.3.18 and 4.3.26, met some errors. Searching in the web found out that 4.3.12 was the last "normally working" version. still in there: http://www.datafilehost.com/d/3b0a4d47 Quote Link to comment Share on other sites More sharing options...
kanyos Posted May 14, 2015 Author Share Posted May 14, 2015 New, version 4.3.28 :thumbsup: Quote Link to comment Share on other sites More sharing options...
spidernz Posted May 21, 2015 Share Posted May 21, 2015 Can anybody upload a repack of 4.3.12 version somewhere, i just couldn't create a virtual machine using the version 4.3.18 and 4.3.26, met some errors. Searching in the web found out that 4.3.12 was the last "normally working" version. still in there: http://www.datafilehost.com/d/3b0a4d47 oo thank you just had same issue as chymax3m too. Quote Link to comment Share on other sites More sharing options...
alfreire Posted May 21, 2015 Share Posted May 21, 2015 (edited) Now I haven't got any problems with new VirtualBox versions, my problem was to have uxtheme.dll file patched... after restore original dll file, all works perfect... it's important that System files don't be patched, must be originals...Regards... ;-) Edited May 24, 2015 by alfreire Quote Link to comment Share on other sites More sharing options...
kanyos Posted July 31, 2015 Author Share Posted July 31, 2015 updated to newest: v5.0.0-101573 :beerchug: alfreire 1 Quote Link to comment Share on other sites More sharing options...
kanyos Posted August 14, 2015 Author Share Posted August 14, 2015 new, version 5.0.2 :beerchug: alfreire and kirk 2 Quote Link to comment Share on other sites More sharing options...
Paoli Posted August 14, 2015 Share Posted August 14, 2015 Hi, can I "install over/update" my 5.0 (with your own installer) with the new 5.0.2 (your installer too)? Quote Link to comment Share on other sites More sharing options...
kanyos Posted September 10, 2015 Author Share Posted September 10, 2015 Hi, can I "install over/update" my 5.0 (with your own installer) with the new 5.0.2 (your installer too)?yes it can be overwrite/ updated from previous versionslatest version: 5.04 :beerchug: alfreire 1 Quote Link to comment Share on other sites More sharing options...
kanyos Posted October 4, 2015 Author Share Posted October 4, 2015 new version: 5.0.6 :beerchug: alfreire 1 Quote Link to comment Share on other sites More sharing options...
kanyos Posted October 21, 2015 Author Share Posted October 21, 2015 updated to 5.0.8 :icon_cool: Quote Link to comment Share on other sites More sharing options...
AntonioLV Posted October 23, 2015 Share Posted October 23, 2015 Please back VBoxREM64.dll, because if in VM settings System>Acceleration is checkbox "EnableVT-x/AMD-V", VM fail to start, even in 32-bit guest and host. alfreire 1 Quote Link to comment Share on other sites More sharing options...
kanyos Posted October 24, 2015 Author Share Posted October 24, 2015 Please back VBoxREM64.dll, because if in VM settings System>Acceleration is checkbox "EnableVT-x/AMD-V", VM fail to start, even in 32-bit guest and host. thanks for correctionre-upload Quote Link to comment Share on other sites More sharing options...
