[True Addon] Mona UltraPacK v3.3.4
  • Replies 59
  • Views 37.5k
updated to 3.2.2
mona, do you have the QTTabBar (last version) addon?
I have the installer, the myconfig.reg and the spanish.xml lang but I don't have idea how I can create It.
hi kassyan
last version here v1.5.0.0 Beta 2
i maked it for you.so first test and tell me work or not,and for add your setting you must repack addon
first open QTTabBar.inf in notepad2 and find ;### User Setting ##; then delete every line have the
HKCU (Except below Line if you want change language) then add your setting
and for change language to spanish remove "; " from first line
;HKCU,"Software\Quizo\QTTabBar","LanguageFile",0x0,"%16422%\Utility\QTTabBar\Lng_QTTabBar_Spanish.xml"
language enable
use reg2inf tool to convert myconfig.reg to inf file. then copy inf registry line to QTTabBar.inf
also remove this line from your inf file
Edit:
now added all plugins and language and theme
default theme aero
Download inside Mona_Ultra_Addon Folder
Edited by mona
thank you very much
if you knew how to get under that styler bar automatically It'll be very helpful. as it is placed below the styler bar.
and how to disable QTTabBar standar buttons?
which files are for themes?
thanks for help mona and sorry my english.
Edited by kassyan_123
thank you very much
and how to disable QTTabBar standard buttons?
Hi kassyan
you need something look like this?
post-7011-0-34267100-1321094990_thumb.pn
if that it,follow this step
1.download [AddOn] Styler ToolBar v1.401 by ricktendo64
1.1.extract this add-on,then download and use StylerTB.inf to install it StylerTB.rar
use inf attachment to install it
1.2.install StylerTB.exe that inside add-on.
1.3.now install QTTabBar or if already installed dont need to install it again
1.4.now right click on toolbar of windows explorer and Uncheck Look The Toolbar
NOW you must uncheck other item like (standard button,address bar,QTTab Standard Button
Qt Addressbar ),then you must enable your favorite item like styler toolbar and QTTabBar
now you can move up styler toolbar over QTTabBar,then right click on styler toolbar and check
look the toolbar.
1.5.now you must go to registry.so go to this patch
HKCU,"Software\Microsoft\Internet Explorer\Toolbar\ShellBrowser"
then export to registry file.now convert regisry file to an inf file,use reg2inf to do it.
open inf file and just keep the line that have ITBarLayout
so this is my registry my.also you can add your this line to registry section of QTTabBar addon so this apply automatic
HKCU,"Software\Microsoft\Internet Explorer\Toolbar\ShellBrowser","ITBarLayout",0x1,11,00,00,00,4c,00,00,00,00,00,00,00,22,00,00,00,10,00,28,00,66,00,00,00,02,00,00,00,28,07,00,00,49,00,00,00,05,00,00,00,6a,05,00,00,00,00,00,00,01,00,00,00,29,07,00,00,41,00,00,00,0b,00,00,00,20,05,00,00,00,00,00,00,09,00,00,00,21,05,00,00,a4,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,0e,47,bf,d2,1c,ed,7f,48,a3,33,2b,d8,83,5e,b6,ce,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,19,f9,f8,d2,0b,69,a2,4e,9f,a7,a2,03,d1,e0,4f,75,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00
and about theme, theme of QTTabBar are installed in
this patch
C:\Program Files\Utility\QTTabBar\Theme
to change theme open QTTabBar setting dialog and go to appearance tab
also to correct installation them you must use infosetting.txt that here
my add on install areo theme,that above screen shot have aero theme
Also please tell me QTTabBar addon on your pc work without error or no?
Edited by mona
hi
also check Styler true add-on
i will add QTTabBar and Styler addon in mona ultrapack in next version
Edited by mona
hiiiiiiii mona
thanks for this coll\ection
but i can't download from this link
pls i need another link
megaplode
ifile
jampufile
please please please please
not forget this
<<<<< i need to convert reg to inf HOW? in attach ???????>>>>>>
mpc.reg
@eltunisie,
The secret to being able to download from mona's link is you MUST be logged into hotfile, at least that works for me. Creating a hotfile account is quick and free.
For the alternatives you mentioned:
megaplode - must be megaupload.com
ifile - must be ifile.it
jampufile - ??? - Google doesn't find anything close to this spelling
For the reg to inf - you could try the on-line converter here - http://vb.nl.eu.org/homepage/reg2peinf.aspx - or try Reg2Inf Converter v0.46 described here - http://www.ryanvm.net/forum/viewtopic.php?t=2169. The download is also a skydrive link, but you do NOT have to be logged into hotfile for access, so that might work for you.
(Since it apparently is possible to set up downloads that do not require hotmail login, hopefully mona's links could be modified in such a way to remove the login requirements as well? That would probably make it easier for some people.)
updated.
@eltunisie
must file sharing site are filtered in my country.so can not upload
other place.also i dont have time to upload another place.
for converting registry use reg2inf from send to menu on right click
Edited by mona
  • 4 weeks later...
hi
updated to 3.2.4
if anyone can make mirror link
i will place it on frist post.like mediafire
Edited by mona
I get this message when i try to download ist from the site:
https://skydrive.liv...&avres=Infected
SkyDrive heeft ontdekt dat Mona_Ultra_Addon_v3.2.4.7z een virus bevat dat schade aan de computer kan toebrengen. Het wordt aanbevolen om het downloaden van dit bestand te annuleren.
Ik ben mij ervan bewust dat dit bestand schade aan mijn computer kan toebrengen.
...From Dutch to Englisch sort way of saying = Skydrive hase discoverd a virus that can be harmfull to you're pc
I try and look into later what the online skydrive is seeing as a virus.
It might see taskkill.exe ash harmfull?
Edited by UtCollector
Yes, there is no need to worry. As Mona stated in the first post:
you may get Mona_Ultra_Addon_v3.0.7z contains a virus,this is a for Reg2exe.exe this is False positive
hi
updated to 3.2.5
Nice thx, I tested it under VM and all seems iinstalled. I got: 144mb installed. 1.674 files and 295 directory's. Great work. that it all can be uninstalled true the software list. Amazing work) Maybe a bit much cab tools in the pack!? I only dont like the menu when clicking the right mouse button. If i may ask. What is the name of it. I would like to take it out of the addon.
Tool For Rightclick Are MMM Free.
thanks for look
updated to 3.2.6
  • 4 weeks later...
updated to 3.2.7
updated. ;)
updated.
  • 4 weeks later...
updated
updated
