Jan Krohn Posted August 2, 2019 Share Posted August 2, 2019 (edited) This will probably be the last chance to get Windows 7 and Office 2010 downloads, before Microsoft drops support for these products in early 2020. Starting October 1, 0:00 UTC, the download database on the server will be reset on the first day of every month. We will then generate one link per hour on a first come first served basis, whatever is requested, until all licenses are used up. The database is then again reset on the first day of the following month, and downloads can be provided again for some time. Requesting a download can result in one of the four following cases: 1. A license for link generation of the requested file is currently available, and the last link generation on the server has happened more than an hour ago ---> new link generation will be attempted, and if successful, the download can be provided. 2. The requested download has been requested and generated in the last 24 hours ---> cached download link will be provided (cached downloads are indicated with a green font in the download tool). 3. All licenses for the product have been used up ---> come back and try again next month after the database reset. 4. A license for link generation of the requested file is currently available, however, the server did another link generation for a different product in the last hour ---> come back and try again in one hour, and be faster than everyone else. I will think about error messages so that you guys can distinguish between cases 3. and 4. easily. Let's see how this will go. Hopefully everyone can still get all downloads they need before MS takes them down for good... Edited September 23, 2019 by Jan Krohn Caue Praxedes, Abdellah Benaissa, SunLion and 2 others 4 1 Quote Link to comment Share on other sites More sharing options...
puppet91 Posted August 9, 2019 Share Posted August 9, 2019 meaning on tab windows 7 is to get the latest iso while the tab windows 7 (august 2018) is older iso? ABDELLAH 1 Quote Link to comment Share on other sites More sharing options...
Jan Krohn Posted August 11, 2019 Author Share Posted August 11, 2019 No, the Windows 7 tab is always the older iso. Abdellah Benaissa 1 Quote Link to comment Share on other sites More sharing options...
Jan Krohn Posted August 22, 2019 Author Share Posted August 22, 2019 So the coding for the October 1 download day is in place and confirmed working. Let's hope it will continue working in productive conditions too. Case 3 message: "This file is currently unavailable, and can be provided again in a small capacity NEXT MONTH. For now, please select one of the downloads highlighted in green instead." Case 4 message: "New downloads can be generated SHORTLY. In the mean time, you can select one of the downloads highlighted in green." Messages will not be translated due to the short life span of a few months only before Win 7 EOL. Quote Link to comment Share on other sites More sharing options...
Princess Omo Posted August 31, 2019 Share Posted August 31, 2019 why is it currentry unavailable when i try to download it Quote Link to comment Share on other sites More sharing options...
Jan Krohn Posted August 31, 2019 Author Share Posted August 31, 2019 10 hours ago, Princess Omo said: why is it currentry unavailable when i try to download it The licenses used to generate the downloads have been blocked by MS. Quote Link to comment Share on other sites More sharing options...
AlikPolskiYouTuber Posted August 31, 2019 Share Posted August 31, 2019 W dniu 2.08.2019 o 19:05 Jan Krohn powiedział: Będzie dostępna ostatnia szansa na pobranie systemu Windows 7 i pakietu Office 2010, zanim Microsoft zrezygnuje z obsługi tych produktów na początku 2020 roku. Poczta pobierania od 1 października, 0:00 UTC, baza danych pobieranie będzie resetowana co miesiąc. Następnie należy wygenerować jeden link na godzinę według kolejności zgłoszeń, aż do wyczerpania wszystkich licencji. Baza danych jest następnie ponownie resetowana pierwszego dnia spotkania Żądanie pobrań może zostać użyty jeden z czterech różnych przypadków: 1. Dostępna jest licencja, a ostatnie generowanie linków wymaga ponad godzin temu ---> podjęto decyzję o podjęciu próby wygenerowania nowego linku, a jeśli powiesz, pobierz będzie możliwe. 2. Zażądano i wygenerowano to samo pobieranie w ciągu ostatnich 24 godzin ---> zostanie podany link do pobrania z pamięci podręcznej. 3. Wszystkie licencje na produkt zostały zużyte ---> wróć i kontynuuj ponownie w przyszłym miesiącu. 4. Licencja jest dostępna, ale w ciągu ostatnich godzin wykonano kolejne generowanie linków ---> wróć i uruchom ponownie w krótkim czasie. Pomyślę o komunikach o błędach, abyście mogli łatwo rozróżnić przypadki 3. i 4 .. Zobaczmy, jak to pójdzie. Mam nadzieję, że wszyscy nadal muszą mieć wszystkie potrzebne pliki, zanim MS usunie je na dobre ... Quote Link to comment Share on other sites More sharing options...
popeye 21 Posted September 7, 2019 Share Posted September 7, 2019 i noticed that in the dell option there was no metion of xps 9100 computer Quote Link to comment Share on other sites More sharing options...
陳順義 Posted September 9, 2019 Share Posted September 9, 2019 i noticed that in the dell option so is there opyion for Acer?? Quote Link to comment Share on other sites More sharing options...
ISO IS GOOD Posted September 10, 2019 Share Posted September 10, 2019 Hello i want to get to this experiment at October 1 Quote Link to comment Share on other sites More sharing options...
Jan Krohn Posted September 12, 2019 Author Share Posted September 12, 2019 On 9/7/2019 at 5:37 AM, popeye 21 said: i noticed that in the dell option there was no metion of xps 9100 computer If you post a service tag, I can try to add XPS 9100. But I don't think it's really necessary. I all likelihood, the download is identical to XPS 8900. Quote Link to comment Share on other sites More sharing options...
Jan Krohn Posted September 12, 2019 Author Share Posted September 12, 2019 On 9/9/2019 at 4:58 PM, 陳順義 said: i noticed that in the dell option so is there opyion for Acer?? Unfortunately no. Acer doesn't provide a public API for generating downloads. Quote Link to comment Share on other sites More sharing options...
Luan Posted September 17, 2019 Share Posted September 17, 2019 Vocês ainda estão liberando o download do windows 7 Português? Quote Link to comment Share on other sites More sharing options...
mooms Posted September 17, 2019 Share Posted September 17, 2019 Please post in English so everyone can read you. Quote Link to comment Share on other sites More sharing options...
SnowBall Posted September 17, 2019 Share Posted September 17, 2019 7 hours ago, Luan said: Are you still releasing windows 7 download? Microsoft is the one who releases all Windows 7 downloads generated by the ISO Downloader. Hopefully the ISO Downloader will be able to generate Windows 7 links after the first of October. Maciek Kalisciak 1 Quote Link to comment Share on other sites More sharing options...
Vuk-1 Posted September 20, 2019 Share Posted September 20, 2019 Requesting a download can lead to one of the four following cases: Please explain the cases better; what is and where do I find a license. I only have the code numbers of Win7 and Office10. thanks for the explanation Yours sincerely From Switzerland Quote Link to comment Share on other sites More sharing options...
cinca Posted September 22, 2019 Share Posted September 22, 2019 (edited) Is there any chance of getting Win 7 Ultimate 64x for the Dell Vostro 1220? Thank you. Edited September 22, 2019 by cinca Quote Link to comment Share on other sites More sharing options...
Hillion Posted September 23, 2019 Share Posted September 23, 2019 Can't download Windows 7 in the Windows iso downloader says Currently unavailable Quote Link to comment Share on other sites More sharing options...
Hillion Posted September 23, 2019 Share Posted September 23, 2019 On 8/2/2019 at 8:05 PM, Jan Krohn said: This will probably be the last chance to get Windows 7 and Office 2010 downloads, before Microsoft will drop support for these products in early 2020. Starting October 1, 0:00 UTC, the download database will be reset every month. We will then generate one link per hour on a first come first served basis, until all licenses are used up. The database is then again reset on the first of the following month. Requesting a download can result in one of the four following cases: 1. A license is available, and the last link generation has happened more than an hour ago ---> new link generation will be attempted, and if successful, the download can be provided. 2. The same download has been requested and generated in the last 24 hours ---> cached download link will be provided. 3. All licenses for the product have been used up ---> come back and try again next month. 4. A license is available, but another link generation was done in the last hour ---> come back and try again in a short time. I will think about error messages so that you guys can distinguish between cases 3. and 4. easily. Let's see how this will go. Hopefully everyone can still get all downloads they need before MS takes them down for good... Is it now absolutely impossible to get Windows 7 iso because i really need it Quote Link to comment Share on other sites More sharing options...
Jan Krohn Posted September 23, 2019 Author Share Posted September 23, 2019 57 minutes ago, Hillion said: Is it now absolutely impossible to get Windows 7 iso because i really need it It's not impossible. There are helpful forum users here who can help with a request. There are also illegal download sites, however, they may not be shared here. You'll find them easily by googleing the file name or the hash of the file you need. On 9/22/2019 at 5:01 AM, cinca said: Is there any chance of getting Win 7 Ultimate 64x for the Dell Vostro 1220? Thank you. If you share your service tag, I can have a look, but I don't have much hope. Dell seems to provide only Win 7 Pro and Home Basic for public download. On 9/20/2019 at 3:28 PM, Vuk-1 said: Requesting a download can lead to one of the four following cases: Please explain the cases better; what is and where do I find a license. I only have the code numbers of Win7 and Office10. thanks for the explanation Yours sincerely From Switzerland Cases are updated with more details. Quote Link to comment Share on other sites More sharing options...
Johsp Posted September 24, 2019 Share Posted September 24, 2019 On 8/2/2019 at 12:05 PM, Jan Krohn said: This will probably be the last chance to get Windows 7 and Office 2010 downloads, before Microsoft drops support for these products in early 2020. Starting October 1, 0:00 UTC, the download database on the server will be reset on the first day of every month. We will then generate one link per hour on a first come first served basis, whatever is requested, until all licenses are used up. The database is then again reset on the first day of the following month, and downloads can be provided again for some time. Requesting a download can result in one of the four following cases: 1. A license for link generation of the requested file is currently available, and the last link generation on the server has happened more than an hour ago ---> new link generation will be attempted, and if successful, the download can be provided. 2. The requested download has been requested and generated in the last 24 hours ---> cached download link will be provided (cached downloads are indicated with a green font in the download tool). 3. All licenses for the product have been used up ---> come back and try again next month after the database reset. 4. A license for link generation of the requested file is currently available, however, the server did another link generation for a different product in the last hour ---> come back and try again in one hour, and be faster than everyone else. I will think about error messages so that you guys can distinguish between cases 3. and 4. easily. Let's see how this will go. Hopefully everyone can still get all downloads they need before MS takes them down for good... If October 1 is restored, does that mean that the downloads can be generated from that day? If so, I will be there without a doubt being one of the first since I need to download Win7 Ult Spanish x64 Quote Link to comment Share on other sites More sharing options...
SnowBall Posted September 24, 2019 Share Posted September 24, 2019 8 hours ago, Hillion said: Can't download Windows 7 in the Windows iso downloader says Currently unavailable 8 hours ago, Hillion said: Is it now absolutely impossible to get Windows 7 iso because i really need it If you can tell me the edition and architecture you need (given that you want English ISOs), I will be able to provide you with a link. Funny that a lot of users simply neglect other threads/topics/posts and I should start charging money for every link given to them. Quote Link to comment Share on other sites More sharing options...
Jan Krohn Posted September 24, 2019 Author Share Posted September 24, 2019 9 hours ago, Johsp said: If October 1 is restored, does that mean that the downloads can be generated from that day? If so, I will be there without a doubt being one of the first since I need to download Win7 Ult Spanish x64 It's an experimental feature. Downloads will be generated at an extremely slow rate to avoid being blocked by Microsoft. From the tests I've made, I'm confident that it's going to work, but only at a rate of one download per hour, for about 20,000 daily users... Therefore, chances for people to get the exact download they need might be a bit low. But if you need an Ultimate download, you can still go for a different edition (Home, Pro), and convert the iso file to an all-in-one file. Johsp 1 Quote Link to comment Share on other sites More sharing options...
BelalAShareb Posted September 24, 2019 Share Posted September 24, 2019 Hi, I'm currently downloading windows 7 (August 2018), the second option on the Windows tab, what is it and how is it different from windows 7, the first choice on the list? Also, is this legal? Thanks! Quote Link to comment Share on other sites More sharing options...
Allan Freitas Posted September 24, 2019 Share Posted September 24, 2019 oi Quote Link to comment Share on other sites More sharing options...
