WiFi keep cutting win10 pro
please i need help :
my laptop original version windows 10 home single language i do pay retell key after paying OEM key so now i do have windows 10 pro version 1809 os build 17763.720.... My problem if i do upgrade to 1903 or 1809  i get problem with wireless keep cutting because i use ALFA model AWUS036ACH
and diagnostics & feedback cant use any one of them + some setting are hide
i do found these program HEIDOC,NET  but what i must to setup win10 pro or DELL OEM image ?
i do use DELL Inspiron 15R 5537 cant found OEM image disk in that program and owner of that program told me to use file W52RRA04_W10x64ROW_pro.iso
but now i am confuse what i must to do
can any one help pleas ?
thanks
Edited by jofii
Link to post
Share on other sites
If you joined a domain, then those restrictions should be set by your system administrator. If it is your personal computer, I suggest you simply refresh Windows 10 and hopefully it will fix your WIFI problem. Also very important, you go to Settings > Update and Security > Troubleshoot instead of Privacy > Diagnostics and feedback if you want to run diagnostics!
Have a nice day,
SnowBall
Link to post
