大†Shinegumi†大 Posted May 9, 2022 Share Posted May 9, 2022 (edited) A free screen recorder helps record every important and precious moment in daily life. Try iTop Screen Recorder and easily count those moments all! Flexible Screen Capture Select any area of your screen to start recording, from the entire display to a small dialog box. iTop Screen Recorder supports multiple displays. Capture every detail and cut off every interference. Facecam Recording A perfect screen recorder is not only a perfect screen record copy but more than it. iTopScreen Recorder provides you with a Facecam function, allowing you to record your face in a video. Using Facecam in many situations, like online tutorials, game recording, PowerPoint presentations. No Lagging While HD Recording Optimizing over and over, iTop Screen Recorder achieves an average 8% CPU utilization, making extremely smooth recording possible. Like flowing air surrounding you: hardly felt, but always by your side. Take While Recording Both dynamic and static are equal and parallel. Since that, we break through technical barriers between video & audio recording and screen capture taking simultaneously. To give users better using experience, we never stop trying. Multiple Output/Convert Formats Trying to cover different groups' demands, more than 12 output formats are supported to be storage and conversion to other formats you want. Compatible with any mainstream digital devices, from your up-to-date iPhone to your mama's old MP4 player. Record the Screen with Audio Experience the most excellent screen recorder with audio. Every syllable of inside background, speaker and tiny microphone on your headset are completely recorded. From image to audio, we are professional. Operating System:Windows 7, 8/8.1, 10 Silent installation Edited June 2, 2022 by Jan Krohn removed links Quote Link to comment Share on other sites More sharing options...
Jan Krohn Posted June 2, 2022 Share Posted June 2, 2022 This is the pro version, and not the free version. Posting is therefore not allowed. I'm removing the links. In the future, make sure to post repacks of free software only. Quote Link to comment Share on other sites More sharing options...
