Need help with first addon
I need some help with this addon, it installs and uninstalls without a problem, but the shortcuts are missing :crying_anim02: .
Can someone point me in the right direct, as to what I am doing wrong. ;);) Thanx
[Version]
Signature="$Windows NT$"
[Optional Components]
BFNE
[DefaultInstall]
AddReg =BFNE.AddReg
CopyFiles =BFNE.Files
ProfileItems=BFNE.AddShortcut,Uninstall.AddShortcut
[BFNE]
OptionDesc ="BFNE"
Tip ="Batch FileName Editor"
Modes =0,1,2,3
AddReg =BFNE.AddReg
[DestinationDirs]
BFNE.Files=16422,%Bfedir%
[SourceDisksNames.x86]
1="Windows XP CD-Rom","BFNE.CAB",,"i386"
[SourceDisksFiles]
file.chm=1
License.txt=1
Name1.exe=1
Name2.dll=1
Readme.txt=1
uninstal.exe=1
uninstal.ini=1
[BFNE.Files]
filenameditor.chm,file.chm
License.txt
Nameditor.exe,Name1.exe
Nameditshell.dll,Name2.dll
Readme.txt
uninstall.exe,uninstal.exe
uninstall.ini,uninstal.ini
[BFNE.AddShortcut]
Name =Batch FileName Editor 4.5
CmdLine =16422,%Bfedir%,Nameditor.exe
SubDir =%Bfedir%
WorkingDir="16422,%Bfedir%"
InfoTip =Batch File Rernamer
[Uninstall.AddShortcut]
Name =Unistall
CmdLine =16422,%Bfedir%,uninstall.exe.
SubDir =%Bfedir%
InfoTip =Uninstall
[BFNE.AddReg]
REMOVED
[Strings]
Bfedir=Batch FileName Editor
Edited by Audigy
Link to post
Share on other sites
OK, make a shortcut for that file.
Batch FileName Editor 4.5.lnk (something like that)
EX.
CopyFiles =AddShortcut.Files
[SourceDisksFiles]
PowerISO.lnk =1
[AddShortcut.Files]
PowerISO.lnk
Remove the other shortcut section you made.
I find this way easier.
Edited by LUZR4LIFE
Link to post
EX.
[SourceDisksFiles]
PowerISO.lnk =1
[AddShortcut.Files]
PowerISO.lnk
Ok LUZR4LIFE, I will give that try.... ;)
Change:
To:
Name	  ="Batch FileName Editor 4.5",8,23
and change:
Name	  =Unistall
To:
Name	  ="Unistall",8,23
This should do the trick.
Ive tried that Jonnyboy, but still no luck. :(
Link to post
I think the error is here:
Should be:
Bfedir="Batch FileName Editor"
in addition the other changes in my previous post.
When the inf tries to make the shortcut it will silently fail if it can't find the file c:\Program files\Batch FileName Editor\Nameditor.exe
Because of the spaces the inf will not be able to create the shortcut, without wrapping the %Bfedir% in quotes.
Edited by Jonnyboy
Link to post
I have made all the changes you suggested Jonnyboy, but it still doesn't work :(:(
Updated INF:
[Version]
BFNE
[DefaultInstall]
AddReg =BFNE.AddReg
[BFNE]
OptionDesc ="BFNE"
Modes =0,1,2,3
AddReg =BFNE.AddReg
[DestinationDirs]
[SourceDisksFiles]
file.chm=1
License.txt=1
Name1.exe=1
Name2.dll=1
Readme.txt=1
uninstal.exe=1
uninstal.ini=1
[BFNE.Files]
License.txt
Readme.txt
[BFNE.AddShortcut]
SubDir =%Bfedir%
WorkingDir=16422,%Bfedir%
InfoTip =Batch File Renamer
SubDir =%Bfedir%
InfoTip =Uninstall
[BFNE.AddReg]
REMOVED
[Strings]
Link to post
OK, Thanks. Try this. Also why did you change the file names?
[BFNE.AddShortcut]
SubDir =Batch FileName Editor 4.5
WorkingDir =16422,%Bfedir%
Name =Unistall
InfoTip =Uninstall
Also take a look at this. Batch FileName Editor 4.5
Sometimes shortcuts will not work so here is an alternative. I have not tested it yet, I need to setup a XP on VMW. All you need to do is use the modded .inf, add the 2 files to your .cab and arc.
Let me know if that worked.
Edited by LUZR4LIFE
Link to post
LUZR there is a solution to ProfileItems (shortcuts) with spaces in the EXE name...just use the 8.3 filename example
Change
CmdLine=16422,SubFolderName,EXE Name.exe
To
CmdLine=16422,SubFolderName,EXENAM~1.EXE
You can use CMenu if you have it to get the 8.3 filename, just right click on the EXE Name and choose: More Options -> Path To Clipboard -> 8.3 Name
BTW you DONT have to change the name of EXE Name.exe in CopyFiles just the shortcut's command line
Link to post
[BFNE.AddShortcut]
Name =Unistall
InfoTip =Uninstall
I was just trying different thinks with the filenames to see if I could get it to work.
I have tried your modded .inf & added the .lnk files, but FGCBA gives me an error....
Error Msg
Link to post
Change
To
Thanx for the info ricktendo64, you made it all look so easy in your tutorial :worthy: , but its not :D:D
LUZR4LIFE, I have just created an addon using the new 5.3 version, and the shortcuts work fine with that :g:
Link to post
