KMPlayer Association
thilakshan
 Share
Hi i was wondering if there is a way to make kmplayer the default player with registry and wht not
i really like this player and i want it to take over media player after the first logon makeing kmplayer the default player to play both dvd/media/audio
thanks alot
Link to comment
Share on other sites
thanks alot
thilakshan why did you open another thread (and other two forums as well) for this? since I already replied you.
It's not problem to do it,but it takes time to sweep like more than 3000 registry entries each one, one by one to remove/edit what is necessary so that KMplayer would be associated as default player for nearly 40 associations + DVD,AUDIO,AUDIO CD,... like I posted on screenshot in my previous post mentioned above.
People have other obligations too other than jumping ASAP as other people would wont them to do.
Please be patient and level headed when asking and opening another threads.
Edited by Gorki
Link to comment
Gorki, I was thinking, rather than registering the file association manually, how about I try using autoit to launch the player, going into the association/capture screen, and associate all extension (using Select All button), then close the program? Thus letting the program write into the registry. Less error of course and u do not have to comb 3000+ registry entries manually.
Link to comment
well better than all this
just run RegShot and take a shot
then go into KMplayer and associate all extension
then make the second shot and then you got all the registery to need
a small check and it`s on
Link to comment
 Share
