Alpha_95 Posted May 1, 2009 Share Posted May 1, 2009 (edited) Hello all,edit :The installation goes well but the uninstallation problem...My inf :http://pastebin.com/m5496a81The icon in the Quick Launch toolbar is not removed and files (README and website) located in %ALLUSERSPROFILE%\Start Menu\Programs\My_Prog\, is not deleted.Yet the file was in C:\Program Files has been deletedthanks for help Sorry if my English is bad, I'm french. Edited May 3, 2009 by Alpha_95 Quote Link to comment Share on other sites More sharing options...
Alpha_95 Posted May 2, 2009 Author Share Posted May 2, 2009 Update topic Quote Link to comment Share on other sites More sharing options...
OnePiece Posted May 2, 2009 Share Posted May 2, 2009 (edited) when you remove, should not the WorkingDir=xxxxxxx[QuickLaunch.delAddShorcut]Name =SIW,0x0000000A,26Subdir =%SIW_SUPP_DIR%WorkingDir=16422,SIW >> should not Edited May 2, 2009 by OnePiece Quote Link to comment Share on other sites More sharing options...
Alpha_95 Posted May 2, 2009 Author Share Posted May 2, 2009 (edited) when you remove, should not the WorkingDir=xxxxxxxokay also :[QuickLaunch.AddShorcut]Name =SIW,0x00000008,26CmdLine =16422,SIW,SIW.exeSubdir =%SIW_SUPP_DIR%InfoTip =SIW Ultimate Edited May 2, 2009 by Alpha_95 Quote Link to comment Share on other sites More sharing options...
OnePiece Posted May 2, 2009 Share Posted May 2, 2009 (edited) [sIW.Uninstall]BeginPrompt =BeginUnInsPromptEndPrompt =EndUnInsPrompt ?????????????????RunPreSetupCommands=CloseProgram:1UnRegisterDLLs =ShellExtensionU.UnRegisterDelFiles =SIW.Files,INFDelDirs =DelDirsSectionDelReg =SIW.delRegProfileItems =Desktop.delAddShorcut,SIW.delAddBookmark,eula.delAddShorcut,QuickLaunch.delAddShorcutUpdateInis =sysoc.cleanCleanup =1[sIW.Uninstall]BeginPrompt =BeginUnInsPromptRunPreSetupCommands=CloseProgram:1UnRegisterDLLs =ShellExtensionU.UnRegisterDelFiles =SIW.Files,INFDelDirs =DelDirsSectionDelReg =SIW.delRegProfileItems =Desktop.delAddShorcut,SIW.delAddBookmark,eula.delAddShorcut,QuickLaunch.delAddShorcutUpdateInis =sysoc.cleanCleanup =1EndPrompt =EndUnInsPrompt Edited May 2, 2009 by OnePiece Quote Link to comment Share on other sites More sharing options...
Alpha_95 Posted May 2, 2009 Author Share Posted May 2, 2009 EndPrompt =EndUnInsPrompt > [EndUnInsPrompt]Prompt = %EndUnInsPrompt% > EndUnInsPrompt = "SIW a Quote Link to comment Share on other sites More sharing options...
OnePiece Posted May 2, 2009 Share Posted May 2, 2009 (edited) try putting it in the endEDITall delAddShorcut have problems, everyone will have to be this way[QuickLaunch.delAddShorcut]Name =SIW,0x0000000A,26Subdir =%SIW_SUPP_DIR%[Desktop.delAddShorcut]Name =SIW,8,23SubDir =SIWCmdLine =16422,SIW,SIW.exeWorkingDir=16422,SIWInfoTip =SIW Ultimate Edited May 2, 2009 by OnePiece Quote Link to comment Share on other sites More sharing options...
Alpha_95 Posted May 2, 2009 Author Share Posted May 2, 2009 all delAddShorcut have problemswhere ?I don't understand...I have no problem with Desktop.AddShorcut but only with QuickLaunch.delAddShorcut Quote Link to comment Share on other sites More sharing options...
OnePiece Posted May 2, 2009 Share Posted May 2, 2009 (edited) where ?I don't understand...I have no problem with Desktop.AddShorcut but only with QuickLaunch.delAddShorcutsorry, my fault or where the copy Riggi, and Desktop.delAddShorcut not Desktop.AddShorcut[Desktop.delAddShorcut]Name =SIW,8,23SubDir =SIWCmdLine =16422,SIW,SIW.exeWorkingDir=16422,SIWInfoTip =SIW Ultimate Edited May 3, 2009 by OnePiece Quote Link to comment Share on other sites More sharing options...
ricktendo Posted May 2, 2009 Share Posted May 2, 2009 You cannot use the same ProfileItem to add and delete a shortcut Quote Link to comment Share on other sites More sharing options...
Alpha_95 Posted May 2, 2009 Author Share Posted May 2, 2009 Excuse me but I do not understand your sentence ...ProfileItems = Desktop.AddShorcut and ProfileItems = Desktop.delAddShorcut does not work if you try to understand? Quote Link to comment Share on other sites More sharing options...
OnePiece Posted May 2, 2009 Share Posted May 2, 2009 (edited) in your file. inf and this critical error that blocked all normal and that everything else after it does not delete them properly removed,first repair the error as already mentioned aboveafter and see if everything ok.I feel better than I can explain it here http://www.wincert.net/forum/index.php?sho...ost&p=47237, I'm sorry, maybe some else can explain better, I do not know....Ciao. Edited May 2, 2009 by OnePiece Quote Link to comment Share on other sites More sharing options...
Alpha_95 Posted May 2, 2009 Author Share Posted May 2, 2009 It remains for me that the problem of deleting quick launch, the rest is solved.My new file. Infhttp://pastebin.com/m71d61ef0SIW.inf and the file is not deleted from C:\Windows\Inf Quote Link to comment Share on other sites More sharing options...
3DotDev Posted May 2, 2009 Share Posted May 2, 2009 It remains for me that the problem of deleting quick launch, the rest is solved.My new file. Infhttp://pastebin.com/m71d61ef0SIW.inf and the file is not deleted from C:\Windows\InfInstead of "INF" Value in the DelFiles Directive put "@SIW.inf" value.I have a question ...Why use an [uninstall] section if U use the original "Uninstaller" (unins000.exe).Perhaps All things don't remove correctly, means that's you're not in the right way...PS : if you want more information in French, do not be shy Quote Link to comment Share on other sites More sharing options...
Alpha_95 Posted May 3, 2009 Author Share Posted May 3, 2009 my uninstall does not work properly so it is discussed at this time, I constantly change the file: pFor delFiles, neither work on. Inf file is not deleted, I'm not shy: p Quote Link to comment Share on other sites More sharing options...
OnePiece Posted May 3, 2009 Share Posted May 3, 2009 try to ask for support here http://www.wincert.net/forum/index.php?showforum=154 Quote Link to comment Share on other sites More sharing options...
Kelsenellenelvian Posted May 3, 2009 Share Posted May 3, 2009 Please ATTACH you're inf as a .txt file to your next post and one of us will fix it. Quote Link to comment Share on other sites More sharing options...
Alpha_95 Posted May 3, 2009 Author Share Posted May 3, 2009 (edited) thanks Onepiece, fortunately I do not redirect the English to their own forum when they ask me for help in my forum ...@KelsenellenelvianThank you but I understand where my mistakes so if you could explain what you were correct ... or if Wallace time to explain? SIW.txt Edited May 3, 2009 by Alpha_95 Quote Link to comment Share on other sites More sharing options...
3DotDev Posted May 3, 2009 Share Posted May 3, 2009 (edited) Alpha_67,OnePiece is right I'll explain which lines aren't necessary in your inf file. Go here and open a topic (if U want) and I can explain you more details in French :http://www.wincert.net/forum/index.php?showforum=154--->For example in your [uninstall] Section this line is not necessary :UnRegisterDLLs =ShellExtensionU.UnRegisterbecause the value isn't any refered in your INF file. That's why the Uninstall Process abort.--->Moreover In your [sourceDisksNames.X86] Only one line is necessary for your Addon : you can delete this :2="INF File","WIN51",,i386----->In your [CloseProgram] section delete this command because "Ricks" said in his TUTO that it's for XP Home compatibility use and tskill fails if you add the file extention (bad example: tskill program.exe)TASKKILL /F /IM SIW.exeI can explain you how to make a custom uninstall section without your original uninstall File (Uninst000.exe) Finally you'll can delete many registry key are not necessary in your [AddReg] and [DelReg] section, and many ShortCuts.See you soon.. Edited May 3, 2009 by wallace1 Quote Link to comment Share on other sites More sharing options...
Alpha_95 Posted May 3, 2009 Author Share Posted May 3, 2009 problem is solved :-)script working nowSIW.txt Quote Link to comment Share on other sites More sharing options...
Kelsenellenelvian Posted May 3, 2009 Share Posted May 3, 2009 Very glad you got it sorted out. Quote Link to comment Share on other sites More sharing options...
Alpha_95 Posted May 4, 2009 Author Share Posted May 4, 2009 and not get an error in a virtual machine but when installing on my PC from the inf, I did not make the mistake ....The icon in the Quick Launch toolbar, if I click on it, he said: :\Documents and Settings\my_user\1 not found ? Quote Link to comment Share on other sites More sharing options...
3DotDev Posted May 4, 2009 Share Posted May 4, 2009 and not get an error in a virtual machine but when installing on my PC from the inf, I did not make the mistake ....The icon in the Quick Launch toolbar, if I click on it, he said: :\Documents and Settings\my_user\1 not found ?The problem seems to be here :CmdLine =16422,SIW,siw.exe 1Remove " 1" like this :CmdLine =16422,SIW,siw.exe Quote Link to comment Share on other sites More sharing options...
Alpha_95 Posted May 4, 2009 Author Share Posted May 4, 2009 The problem seems to be here :CmdLine =16422,SIW,siw.exe 1Remove " 1" like this :CmdLine =16422,SIW,siw.exethanks wallace[HS FR] erreur de copi Quote Link to comment Share on other sites More sharing options...
