pri2sh Posted June 3, 2009 Share Posted June 3, 2009 i think we all know 7zip probably using this also. but it has windows 98 icons which looks odd in pc of now a days.. so i modified look of 7zip to vista like.Bitmap is ported from winrar vista theme and icons are made my me modifying zip icon of vista.This is modified version of 7-Zip v4.65.All old icons/bitmaps has been changes to gloosy vista like icons and bitmaps.The code of 7-zip is not changes and is same as of 7-zip v4.65.To install this move "7z.dll" & "7zFM.exe" to the location where you have installed 7zip.You may have to log off or restart to get change in icon.I don't know who created the 7-zip app logo.. I found this on image search and used it..7-zip is free & open source software u can get 7-zip from 7-zip.org if u want this then download Vista style 7zip from here http://www.deviantart.com/download/1246450...p_by_pri2sh.rar Quote Link to comment Share on other sites More sharing options...
ricktendo Posted June 3, 2009 Share Posted June 3, 2009 OMFG finally!!! I requested this long ago on joejoe.org Any chance you can do Windows Search 4.0?It has allot of potential, you could use the Vista orb for the flag, update some buttons, bitmaps and icons and also the close and minimze buttonsThis would be AWESOME!!! Quote Link to comment Share on other sites More sharing options...
x-shadow-x Posted June 3, 2009 Share Posted June 3, 2009 Yes, this is very nice. Going to download rite away. Quote Link to comment Share on other sites More sharing options...
pri2sh Posted June 4, 2009 Author Share Posted June 4, 2009 thanks for suggestion rick.. i am thinking of putting some 7 stuffs(since windows7 have some similar stuff like of vista). Quote Link to comment Share on other sites More sharing options...
