[solved] Help Inf
Alpha_95
Hello all,
To refresh the control panel after uninstalling, I use reflesh.exe is copied to system32 but it is deleted before and then tells me an error that the specified file is not found ....
Edit: Problem is solved
Edited by Alpha_95
Link to comment
Share on other sites
