[Solved] Problem Inf addon
Alpha_95
Hello
the problem is that the shortcuts are not created (start menu and control panel).
After reboot the PC when running the inf file, I have the settings incorrect error ... I use to test WA install addons.
Inf file:
[Version]
Signature=$Windows NT$
[DefaultInstall]
RegisterDLLs=Install.MI
[install.MI]
11,,rundll32.exe,,,"advpack.dll,LaunchINFSection %1%\MediaInfo.inf,Install"
[install]
AddReg=MI.Reg,MediaInfo.cpl,uninstall.Addreg
ProfileItems=MI.Shortcut,MI.url.Shortcut,MI.chm.Shortcut,MI.Readme.Shortcut
RunPostSetupCommands=RunPostSetupCommands.install
[DestinationDirs]
INF=17
MI.Files=16422,MediaInfo
Plugin.Files=16422,"MediaInfo\Plugin"
Custom.Files=16422,"MediaInfo\Plugin\Custom"
Language.Files=16422,"MediaInfo\Plugin\Language"
Sheet.Files=16422,"MediaInfo\Plugin\Sheet"
Tree.Files=16422,"MediaInfo\Plugin\Tree"
PNF.File=17
DefaultDestDir=17
[sourceDisksFiles]
License.html=1
MediaInfo.url=1
MediaInfo.dll=1
MediaInfo.exe=1
MediaInfo_InfoTip.dll=1
ReadMe.txt=1
History.txt=1
MediaInfo.cfg=1
en.Example.csv=1
en.Example_HTML.csv=1
Example.csv=3
Example_HTML.csv=1
fr.Example.csv=1
it.Esempio.csv=1
it.Esempio_HTML.csv=1
Table by fields, compact (HTML).csv=1
Table by fields, short (HTML).csv=1
Table by fields, standard (HTML).csv=1
Table by fields, verbose (HTML).csv=1
Table by streams, compact (HTML).csv=1
Table by streams, short (HTML).csv=1
Table by streams, standard (HTML).csv=1
Table by streams, verbose (HTML).csv=1
XML.csv=1
zzz_Contrib - Dusil (HTML).csv=1
fr.csv=1
en.csv=1
Export example.csv=1
MediaInfo.inf=2
[MI.Files]
License.html
MediaInfo.url
MediaInfo.dll
MediaInfo.exe
ReadMe.txt
History.txt
[Plugin.Files]
MediaInfo.cfg
[Custom.Files]
en.Example.csv
en.Example_HTML.csv
Example.csv
Example_HTML.csv
fr.Example.csv
it.Esempio.csv
it.Esempio_HTML.csv
XML.csv
[Language.Files]
fr.csv
en.csv
[sheet.Files]
Export example.csv
Example.csv
[Tree.Files]
Example.csv
[MI.Reg]
HKLM,"SOFTWARE\Classes\Folder\shell\MediaInfo",,0x10
HKLM,"SOFTWARE\Classes\Folder\shell\MediaInfo\Command",,0x0,"""%16422%\MediaInfo\MediaInfo.exe"" ""%%1"""
;HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\App Paths\MediaInfo.exe",,0x0,"%16422%\MediaInfo\MediaInfo.exe"
HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\MediaInfo","DisplayIcon",0x0,"%16422%\MediaInfo\MediaInfo.exe"
HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\MediaInfo","DisplayName",0x0,"MediaInfo 0.7.31"
HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\MediaInfo","DisplayVersion",0x0,"0.7.31"
HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\MediaInfo","NSIS:Language",0x0,"1036"
HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\MediaInfo","Publisher",0x0,"MediaArea.net"
HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\MediaInfo","URLInfoAbout",0x0,"http://mediainfo.sourceforge.net"
[uninstall.Addreg]
HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\MediaInfo","UninstallString",0,"rundll32.exe advpack.dll,LaunchINFSection MediaInfo.inf,Uninstallshellext"
HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\MediaInfo","NoModify",0x10001,01,00,00,00
HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\MediaInfo","NoRepair",0x10001,01,00,00,00
[MediaInfo.cpl]
HKCR,"CLSID\{D14ED2E1-C75B-443c-BD7C-111111111197}"
HKCR,"CLSID\{D14ED2E1-C75B-443c-BD7C-111111111197}",,,"MediaInfo"
HKCR,"CLSID\{D14ED2E1-C75B-443c-BD7C-111111111197}","InfoTip",,"MediaInfo fournit des informations techniques et des m
Edited by Alpha_95
Link to comment
Share on other sites
The key HKU,"S-1-5-21-1659004503-796845957-1801674531-1004\* are not to be integrated.
if I understand you well? (They are different in each new installation?)?
HKU may be in HKCU? (because it is the right click menu on a file)
Is it not enough to register MediaInfo_InfoTip.dll?
This is not correct the register ?
Link to comment
Yes your RunOnce (should be RunOnceEx if you use a subdir dont it?) RegisterDLL looks correct, what Im asking is if you just register the DLL and NOT add the HKU,"S-1-5-21-1659004503-796845957-1801674531-1004\* registry entries will the program work just fine without it?
Link to comment
I deleted the key RunOnce, but I just let this one:
HKLM,"Software\Microsoft\Windows\CurrentVersion\RunOnce","Reboot",,"rundll32.exe advpack.dll,LaunchINFSection MediaInfo.inf,DelRegSection2"
replaced by:
HKLM,"Software\Microsoft\Windows\CurrentVersion\RunOnceEx","Reboot",,"rundll32.exe advpack.dll,LaunchINFSection MediaInfo.inf,DelRegSection2"
I do not think it will prevent the proper functioning of the program but when you make a right click on the file, it will no longer choose to open it with MediaInfo ...
Link to comment
No you got me wrong...when you use RunOnceEx you need to add a \SubDir or it will not work.
HKLM,"Software\Microsoft\Windows\CurrentVersion\RunOnceEx\AnySubDir","Reboot",,"rundll32.exe advpack.dll,LaunchINFSection MediaInfo.inf,DelRegSection2"
I was not too sure about your RunOnce\SubDir thats what I was wondering about
Link to comment
Did you delete the AddReg?
Also you may want to have a look at these two shortcuts
[MI.url.Shortcut]
Name ="Site Web De MediaInfo",8,23
SubDir ="MediaInfo"
CmdLine =16422,"MediaInfo","Site Web De MediaInfo"
WorkingDir=16422,"MediaInfo"
InfoTip ="Site web de MediaInfo."
[MI.chm.Shortcut]
Name ="License",8,23
SubDir ="MediaInfo"
CmdLine =16422,"MediaInfo","License.html"
InfoTip ="License de MediaInfo."
Look in my Sidebar addon and you will see how to make URL files with ProfileItems
[BBC6.AddURL]
Name =radio_BBC 6music,0x00000008,38
URL =http://www.bbc.co.uk/6music/ram/6music_hi.asx
SubDir =%WMPST%
IconPath=11,,url.dll
Notice instead of CmdLine= it uses URL=, also notice that I tell it to use the first icon in url.dll (you can leave out InfoTip and WorkingDir for these types of shortcuts)
The second shortcut to the .html file I am not too sure about, if it does not seem to want to create you need to add IconPath= and IconIndex= to specify a icon
But first fix your URL shortcut see if that solves the problem...come back if the .html shortcut does not want to be created
Link to comment
yes, renaming was the solution, thank you to you for your help!
One question, when a file. Ocx or. Dll (RegDllView Entry System 2) is recorded twice, how?
Directory :
%ProgramFiles%\Fichiers communs\Blueberry Software\BBFileTransfer.dll
%ProgramFiles%\Fichiers communs\Blueberry Software\ActiveBand.ocx
"regsvr32.exe /s ""%16422%\BB FlashBack Pro\ActiveBand.ocx"""
"regsvr32.exe /s ""%16422%\BB FlashBack Pro\BBFileTransfer.dll"""
Enough or I have to run a second time?
Link to comment
