cro-man Posted May 9, 2007 Share Posted May 9, 2007 VMware Inc today released version 6 of its virtualization product VMware Workstation. VMware Workstation runs under a wide range of Linux and Windows versions and allows installation of an even wider range of guest operating systems within virtual machines. Among many possible applications are letting help desk personnel easily keep different Windows versions at hand, testing new software products under a variety of environments, and analyzing malicious software without the risk that it might damage a physical computer. Version 6 adds full support for Windows Vista both as host and guest along with significant feature enhancements from the previous version.With this version, VMware's support for Windows Vista moves from "experimental" to mainstream. It fully supports all aspects of Vista inside a virtual machine except for the high-end graphics. At this time it doesn't provide the 3D graphics support necessary for Vista's Aero Glass display mode. However, VMware's senior director of virtual software lifecycle automation James Phillips said that this will change, as the necessary support is "in the lab" at present. Download the datasheet for more information or get an evaluation copy and try it for yourself. Quote Link to comment Share on other sites More sharing options...
Kelsenellenelvian Posted May 9, 2007 Share Posted May 9, 2007 w00t!!! Quote Link to comment Share on other sites More sharing options...
cro-man Posted May 9, 2007 Author Share Posted May 9, 2007 Finally :thumbsup_anim: Quote Link to comment Share on other sites More sharing options...
