December 18, 200718 yr Hellp;Hellp;Hellp MENeed to silent install Pdf Machine 12.12 url:www.broadgun.com http://www.pdfmachine.com/And Ashampoo Magical Snap 2.10And Ashampoo Burning Studio 7.1.0.0When method /silent AND /VERYSILENT /SP USE PROGRAMs Ashampoo run After silent installation during setup windows xp:help me
December 18, 200718 yr IDK if this will work but you can try to kill the task for the Ahampoo soft when it launces (only will work with the new 7zip sfx)Option 1 TASKKILL;!@Install@!UTF-8!GUIMode="2"RunProgram="setup.exe /SP /VERYSILENT"RunProgram="hidcon:cmd /c taskkill /f /im process_name.exe /t";!@InstallEnd@!Option 2 TSKILL;!@Install@!UTF-8!GUIMode="2"RunProgram="setup.exe /SP /VERYSILENT"RunProgram="hidcon:cmd /c tskill process_name";!@InstallEnd@!If you use tskill instead of taskkill don't add the .exe part (BTW the only reason to use tskill is for XP Home compatibility)And tell me one more thing... Do you use nLite or the Integrator, because there may be a way to add your serials if you use nLiteEDIT: I will download the softs later and let you know how and if i was able to install them and kill the app, also will let you know if its possible to add registration. (cant atm because we have some bad weather and flooding)
December 18, 200718 yr OWNED For pdfMachine.exe- Extract the installer to a sub directory- Edit bgsconf.iniquiet = 0- Change to 1quiet = 1Repack the installer and simply make it run bgsSetup.exe
December 18, 200718 yr Here is how you install Magic Snap, stop the browser from running, kill the task and enter your registration;!@Install@!UTF-8!GUIMode="2"RunProgram="ashampoo_magicalsnap230_sm.exe /VERYSILENT /MERGETASKS=!regkey"RunProgram="hidcon:cmd /c tskill ashsnap"RunProgram="hidcon:cmd /c \"reg add \"HKCU\Software\Ashampoo\Ashampoo Magical Snap 2\" /v RegistrationKey /t REG_SZ /d ABCDEF-123456-ABC123 /f\"";!@InstallEnd@!What stops the browser from launching is the /MERGETASKS=!regkey switchHere is how I found out how to stop the browser from launching using CMenu's Identify InstallerInno Setup
December 18, 200718 yr Author VERYVERY THANK YOU .How to use ((code)) ?? whether from method svcpck who insert code to ENTRIES_name soft .INII must code where put IF perchance ONLY CODE PUT FOR DOWNLOAD upto SOFTWARE ASHAMPOO put TO CODE method THEN HELP TO Repack Pdf Machine.Thank you very much.NOT VERY GOOD ENGLISH.
December 18, 200718 yr By the sounds of it you dont know how to make a 7zip switchless installer http://www.wincert.net/forum/index.php?showtopic=1978
