June 22, 200719 yr AddOn posting instructions:1st the Post Tittle...- Try to maximize space but post the name, version and date of release/update of your program addon so it fits in the tittle example[AddOn] My Program v1.2.8 (June-22-07)Converts bla to bleNow the required contents of your post- Post a screenshot of your program addon (You can upload a screenshot to WinCert or you could use a free Image hosting website like Imageshack)- Now followed again by the Program Name, Author and Version- Download Link- MD5 Hash (I use HashTab Shell Extention)- Size of the addon- Changelog (describing any small changes you made)Here is a quick example:ViStart Build 2489 created by Lee Mathew Chantrey & Windows XMD5: 820AAAF4ECC6E7BFECAECE7E65113207Size: 265 KBWebsite: http://www.lee-soft.com/vistart/Download Skins: http://www.lee-soft.com/forums/viewforum.php?f=9WARNING: Don't remove too much start menu stuff with nLite, like Help and Support & Outlook Express because the program might not run.Changelog:06-20-2007- Updated Build 2489- Removed Startup shortcut, does not startup on 1st login (use the program's options to set it to start up)06-6-2007- Updated Beta 5 (no more splashscreen)
