[Addon] FreeCommander v2007.10a
INFO:FreeCommander is an easy-to-use alternative to the standard windows file manager. The program helps you with daily work in Windows. Here you can find all the necessary functions to manage your data stock. You can take FreeCommander anywhere - just copy the installation directory on a CD, USB-Stick or even a floppy disk - and you can even work with this program on a foreign computer.
Website: http://www.freecommander.com/index.htm
MD5 - 040979C9C12F22BA4FCCA48F18E11959
Size - 1.88 MB
Edited by LUZR4LIFE
Thanks!
Does this add the e-bay shortcuts mentioned in the manual install? Just curious, half my users are daily e-bayers, and the other half don't need em, so either answer is the right answer!
Thanks!
I never used this, it was a request. The only shorcuts that install from the program it's self is the .exe and uninstaller. I believe anything else you need to do manually.
