April 13, 201016 yr Microsoft .NET Framework 4.0 Client & Extended FULL - 20100413This is a multimode installer so you have access to the following switches:-ai = Silent-ai1 = Passive /h = displays helpThis package is uninstallable from Add/Remove Programs in Control Panel.The Multimode Installer should be installed from RunOnceEX and not from SVCPACK.If you are not familiar with setting up RunOnceEX than you should download one of the Addons instead.This package has the Client Profile and ExtendedLink: dotNet40.exeCRC-32: 03ec93af MD4: d76c4d6373a8422760573d182f6440a5 MD5: 8cddbac1de11b8980d934ed63f3331a6 SHA-1: 1e486b55f650d3b6a8396bcf7355ce6050b412b7 Date: 20100413 OS: Windows XP SP3 (x86 & x64) Size: 48.7 MB===================================Addon for RVMi 1.6 or higher.Integrate this addon to run the installer at RunOnceEX.There will be progress boxes but NO user interaction is required.Passive mode is used since setup takes a while, this way you will knowwhere you are in the setup process. Final installation will takeplace after OOBE and before Personalized settings occur. Link: Addon_Microsoft.Net_4.0_ROE_20100413.7zCRC-32: a53159f7 MD4: e81db31f12c9dc8e55cc1cefeea1b944 MD5: 7079365bdea24f389e7371fb3d41831d SHA-1: d0a7cce40bb3505a027a60812945c09788c53f16 Date: 20100413 OS: Windows XP SP3 (x86 & x64) Size: 49.3 MB===================================
October 22, 201313 yr Both of the download links for this Add-On are broken. Can you please fix? Thanks in advance!
