[Addon] Java Runtime Environment 6.0 / 7.0 x86/x64
Java Runtime Environment 6.0 Update 45 & 7.0 Update 72 x86/x64
using the following switches: ADDLOCAL=ALL IEXPLORER=1 MOZILLA=1 SYSTRAY=0 JAVAUPDATE=0 JU=0 AUTOUPDATECHECK=0 MODIFYREMOVE=modify
unregisters: jqs.exe
applying the following reg file:
[HKEY_CURRENT_USER\Software\JavaSoft\Java Update\Policy]
"EnableAutoUpdateCheck"=hex:01,00,00,00,d0,8c,9d,df,01,15,d1,11,8c,7a,00,c0,4f,\
c2,97,eb,01,00,00,00,9e,9b,bf,c2,27,b9,97,4f,9e,f0,76,37,a6,00,59,2b,00,00,\
00,00,1c,00,00,00,50,00,61,00,73,00,73,00,77,00,6f,00,72,00,64,00,20,00,44,\
00,61,00,74,00,61,00,00,00,10,66,00,00,00,01,00,00,20,00,00,00,dc,20,72,03,\
cd,3e,fb,cf,34,34,20,b4,69,52,58,ce,54,aa,93,6e,ed,44,31,b7,64,70,e3,1e,67,\
3a,81,c5,00,00,00,00,0e,80,00,00,00,02,00,00,20,00,00,00,19,16,10,6f,3a,80,\
e2,41,b7,60,ac,08,9b,3e,ca,86,ac,d8,6a,a2,ef,46,80,3b,ff,c8,f2,07,00,8c,23,\
a3,10,00,00,00,66,88,0e,7c,44,3c,ef,7b,ab,f0,2e,9a,87,17,34,48,40,00,00,00,\
6d,e8,dc,6a,1a,a5,5c,41,c5,d8,dc,6d,7d,c7,45,c3,3b,e5,57,d8,33,c5,ba,3c,9e,\
16,15,38,30,d7,1b,d0,93,b0,e0,24,9a,44,ba,39,c5,aa,e4,cc,71,53,8b,b2,ba,f8,\
e5,02,0d,d0,a5,be,e4,db,30,a0,aa,e4,5d,fc
[HKEY_LOCAL_MACHINE\SOFTWARE\JavaSoft\Java Update\Policy]
"EnableAutoUpdateCheck"=dword:00000000
"EnableJavaUpdate"=dword:00000000
"NotifyDownload"=dword:00000000
"NotifyInstall"=dword:00000000
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run]
"SunJavaUpdateSched"=-
Link: Addon_Java_Runtime_6_update_45.7z
CRC-32: 59f9c189
MD5: 0baf87a125dfdf91b321ba2a3345a8b3
SHA-1: 7474c1f75fdef93c7fd679245dd94ff3145d22a1
Date: 20130416
OS: WindowsXP SP3 (x86/x64)
Link: Addon_Java_Runtime_7_update_72.7z
CRC-32: 7b0f0bb5
MD5: 7ceb5959e10b5fdb45146e3d89579c44
SHA-1: 2a863f0db65e8f291f7083cbd6ebf84ec5114d5c
Date: 20141030
If you unpack the Addon to get access to the multimode installer you'll have access to the following switches:
-ai = Silent
-ai1 = Passive
/h = displays help
  • 3 months later...
  • Replies 69
  • Views 46.2k
Thank you for the updates.
Is there any version for Win7 x64 or this one can work just fine?
i have not tested this on Win7x64 so i don't know.
perhaps some other user that has can comment.
It does work on Win7 x64.
What I dont know is why there's two versions then. :)
Thank you again for the updates, always useful.
there are different versions of JavaRE.
my installer package is built from the Windows x86 installer "jre-6u25-windows-i586.exe".
it will not work on Win7x64 because of the above.
for Window x64 the installer would have to be built from "jre-6u25-windows-x64.exe"
or "jre-6u25-windows-ia64.exe" if you are using the Intel Itanium.
you can download any of the releases from Oracle jre-6u25-download
