wintoolkit installer not running with my second method
Hello i have one problem with wintookit installer! When i make .iso and next i create a bootable DVD with this .iso , the wintoolkit installer works correct (your program let me choose one or more apps for install on my system win764bit). When i try the same files in this DVD copy into my created partition with xcopy command from ms-dos , (i will to install my win7 without dvd like a recovery partition) , the win7 install correct but next when the wintoolkit installer try to run not works (stuck) , to let me choose my apps like before. the method which i try to copy my created installation dvd into my recovery partition is this:
*sorry for my bad english :( . Thx for your time , i will wait for your instructions :)
Edited by embodio
