May 27, 200718 yr You want to integrate the sidebar into Windows?This is what you use if you want to slipstream it into XP using nLite or the RVM Integrator http://www.wincert.net/forum/index.php?showtopic=485Dont forget to integrate the RTM Fonts, VAIO b2 and WLan API AddOns (if you use the RyanVM Updatepack skip the wlan api addon)
June 1, 200718 yr Author Yes thanks for reply, I have everything working with my sidebar........but I want to update to the latest and it got no installer there........Any else suggestions??
June 2, 200718 yr Im updating it now... Some changes will be:Control Panel ShortcutI will be removing ALL 3rd party gadget (only leaving the originals to save space and install time)Added Vista fonts (segoeui and calibri)Added WLan API Hotfix (also added msxml6)Also adding NeroDiscCopy.Gadget Compatibility files (Read More)If you dont like any of these changes it is easy to install the AddOn manuallyCopy regsvr32.exe from system32 to the same folder as the extracted Sidebar.inf and cabRight on Sidebar.inf and select installBrowse to folder with regsvr32.exe and Sidebar.cab hit Select then OKFinally after install is done copy Sidebar.inf to WINDOWS\inf (tip: its a hidden directory)And Done
