May 28, 200718 yr Hello and thanks all! this site has so much information!I don Edited May 28, 200718 yr by martin
May 28, 200718 yr I would be very glad to help you learn to build your own setup, but I cannot help you modify a warez product...We do not support or condone warez.
May 28, 200718 yr Author Thank you Kelsenellenelvian, I will delete the Warez from my hd and o/s, Because I have the original XP Pro CD if you will help me.,I will be very honored.
May 28, 200718 yr I would be very glad to help you but it is 4:47 am and I got up at 8:00 am yesterday.Go ahead and post here a messenger addy if you have one if not I will dig up a bunch of info for you in the morning (Or afternoon as the case may be:P)nLite, WPI and RVM are 3 things you will very quickly learn to love.
May 28, 200718 yr Author Thanks heaps Kelsenellenelvian,thanx for the material i'll try and obsorb it in tomorrow. I've started to read MSFN's Unattended Windows Introduction. It fascinates me the possibilities of having my very own setup CD with custom updates and hotfixes, apps, and environment. Can't wait[nLite, WPI and RVM are 3 things you will very quickly learn to love] I think so Edited May 28, 200718 yr by martin
May 29, 200718 yr Author This may seem like a ridiclous question to some. But I'll ask anyway. Why is it when I'm extracting sp2.exe ex.. C: cd\sp2 then p2.exe Edited May 29, 200718 yr by martin
