How to switch an index image from a wim to another wim ?
Hello,
I created an updated windws 7 sp1 with update iso.
I don't knwo why but it appeat that my index:6 of my install.wim is corrupt.
I would like to extract the index:6 of a "clean" install.wim and replace to my corrupted index:6 wim.
I try to di this wih dism :
Mounted the good index:6
Renamed the mounted folder.
Unmounted with discard
Mounted the "bad" index:6
Renamed the "good" folder index:6
Unmountend with commit ( in order to save the good index:6 in the install.wim which had the corrupted index:6).
Dism don't want to do this !
I tried with WinToolkit, using the wim manager, and i have exception.
Is there a proper way to do this ?
Anyone could help me please ?
Thanks a lot :)
Best regards,
Nixeus
