February 1, 201412 yr Herewego! Another big ones, i dunno whats going there.My idea is, anything was wrong with memory.(While i test some in vm and use WTK same time, a programm told me that free ram was miss) Exception text: Title: 2 error(s) have occurredErrType: ErrorDescription: Win Toolkit has recorded errors which occurred during integration and have been stored via '>> Details'.Exception:Exception:An error occurred whilst integrating an update!Exception:Microsoft Windows [Version 6.1.7601]Copyright (c) 2009 Microsoft Corporation. All rights reserved.C:\Users\Zer0\Desktop\WinToolkit_1.4.33.2>Set SEE_MASK_NOZONECHECKS=1C:\Users\Zer0\Desktop\WinToolkit_1.4.33.2>"C:\Program Files (x86)\Windows Kits\8.1\Assessment and Deployment Kit\Deployment Tools\amd64\DISM\dism.exe" /Image:"G:\Mount" /Add-Package /PackagePath:"C:\Users\Zer0\Desktop\Updates\Windows7-x86\Extra\WIF Updates\Windows6.1-KB2503351-x86.msu" /ScratchDir:"C:\Windows\Temp\WinToolkit\ScratchDir" /EnglishDeployment Image Servicing and Management toolVersion: 6.3.9600.16384Image Version: 6.1.7601.17514Processing 1 of 1 - Adding package C:\Users\Zer0\Desktop\Updates\Windows7-x86\Extra\WIF Updates\Windows6.1-KB2503351-x86.msuC:\Users\Zer0\Desktop\Updates\Windows7-x86\Extra\WIF Updates\Windows6.1-KB2503351-x86.msu: An error occurred applying the Unattend.xml file from the .msu package.For more information, review the log file. Error: 0x8007000eError: 14The specified image is no longer serviceable.Unmount the image and discard your changes. Mount the original image to try the operation again.The DISM log file can be found at C:\Windows\Logs\DISM\dism.logC:\Users\Zer0\Desktop\WinToolkit_1.4.33.2>exit----------------------------------Something bad has happened to your image and can no longer be worked on! There was no point in continuing.NOTE: This usually happens when you try and integrate a language pack of some sort without integrating the Windows language pack first.-For example, if you want to integrate a French language pack for Internet Explorer. Then you need to make sure to add the French Windows language pack first!Exception:Microsoft Windows [Version 6.1.7601]Copyright (c) 2009 Microsoft Corporation. All rights reserved.C:\Users\Zer0\Desktop\WinToolkit_1.4.33.2>Set SEE_MASK_NOZONECHECKS=1C:\Users\Zer0\Desktop\WinToolkit_1.4.33.2>"C:\Program Files (x86)\Windows Kits\8.1\Assessment and Deployment Kit\Deployment Tools\amd64\DISM\dism.exe" /Image:"G:\Mount" /Add-Package /PackagePath:"C:\Users\Zer0\Desktop\Updates\Windows7-x86\Extra\RSAT Updates\Windows6.1-KB2462585-v2-x86.msu" /ScratchDir:"C:\Windows\Temp\WinToolkit\ScratchDir" /EnglishDeployment Image Servicing and Management toolVersion: 6.3.9600.16384Image Version: 6.1.7601.17514Processing 1 of 1 - C:\Users\Zer0\Desktop\Updates\Windows7-x86\Extra\RSAT Updates\Windows6.1-KB2462585-v2-x86.msu: An error occurred applying the Unattend.xml file from the .msu package.For more information, review the log file. Error: 0x800f0830Error: 0x800f0830DISM failed. No operation was performed.For more information, review the log file.The DISM log file can be found at C:\Windows\Logs\DISM\dism.logC:\Users\Zer0\Desktop\WinToolkit_1.4.33.2>exit---------------------------------- Screenshot (WTK) Additional info:I was re-updating my project-full-iso.In the 7z are all logs, settings, and the .ini. Greez Update:Aaargs max 150 kb Attachments, so:https://mega.co.nz/#!aUpFWCRT!R4e8yFcRcvFduo3Fy3DAUxJNHhA1SHyseMxzD9IZGqY Edited February 1, 201412 yr by BrokenZer0
