Addon Maker
You want to make a addon for a programm shortcut, or what exactly you mean?
(For better understanding, try google translate or tell us your country :) )
yes , make addon with shortcut in taskbar
thanks
Okay, try this:
1. Make a Shortcut of program that you want in this location and make a addon from
(Alternative: make this in mounted image and capture the installation.)
C:\Users\Username\AppData\Roaming\Microsoft\Internet Explorer\Quick Launch\User Pinned\TaskBar
But make sure that you have linked the right location of program in shortcut.
Greez
Probably more information need:
- What for OS (image) u work on ?
- Sure about the rename of "username"?
- Sure about the IE is installed/not removed?
- Sure about to integrate also the addon of program?
- What was your steps?
Im not tested yet, but i think it should work:
1. Make shortcut(s) in the called location on your running system.
(Optional
2. Go there and change the shortcut destination: "C:\program files" -> "%programfiles%"
(/Optional)
3. Addon Maker: Copy this folder "TaskBar" and set destination on:
"%userprofile%\AppData\Roaming\Microsoft\Internet Explorer\Quick Launch\User Pinned\TaskBar"
4. Integrate this addon, and the addon(s) of prgram(s) into the image.
Another idea me came:
1. Mount the image (example with component remover or AIO-Integrator with "Promt Unmount"-Option).#
2. Open mounted system in explorer and make the shortcuts like it would be ur running system.
2. Unmount the image and save/rebuild.
That should work, but i dunno.
