Conflict with USB Drive
I used to set my external hard drive to be the G: drive.  After beginning to use wintoolkit I began having constant issues with the drive dropping off randomly.  This continued to occur even when wintoolkit was not open.  I noted that wintoolkit used its own G: drive for mounted images ?
I performed a reinstall and then set my external drive to drive B:, and since then I have not had the issue.
It seems there was a conflict created in this scenario.
TY
