Hi Lego,
Why checkbox for Delete Silent Installers are always tick? I always uncheck that box ! It could be possibly to delete my apps ? or it's just for integrated updates ?
Thanks !
Edited by KEiGHT
Check box default is ticked, meaning the item will always be installed.  If you wish to be asked, during the install process, if the item is to be installed, the box must be unticked.
