May 13, 201411 yr hi, i have integrated updates up to april 2014 into a windows 7 sp1 x86 and x64 ISOs then i ran WTK again to remove and tweak the installation of both isos the final iso of x86 works perfect , updates, removal, tweak, services and runonce update and few addons. but if i apply the same preset used in x86 to x64 and try to install the runonce module is not loaded, and the addons neither the updates are installed after many tries i discovered (at least i think ) that some service if disabled can mess with the runonce module. first i used the safe preset by blackviper but still same problem, then i disable only few services, then my installation was successful. now i'm wondering which services could mess with the run once installer??? greetings
May 19, 201411 yr NO is NOT Working ! I use 1.4.38.8 and is NOT from Services ! Has nothing to do with them ! Edited May 19, 201411 yr by © KEiGHT
