March 12, 201511 yr Good day gents, Can someone please advise if it is possible to add proxy settings to the image in WTK? All I get is to edit the default home page. TIAJoe
March 12, 201511 yr AFIK , IE store proxy setting in the registry , you did't clarfy your question are you search for way to modify the defualt proxy setting of the IE or somthing else . here is way for doing that vai change the proxy setting in the IE option , and then you should go to the registry find this line :HKLM "SOFTWARE\Policies\Microsoft\Internet Explorer\Control Panel" "Proxy" = 1 HKLM "SOFTWARE\Policies\Microsoft\Internet Explorer\Control Panel" "AutoConfig" = 1 HKLM "SOFTWARE\Policies\Microsoft\Windows\CurrentVersion\Internet Settings" "ProxySettingsPerUser" = 0 HKLM "SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings" "DialupUseLanSettings" = 1 HKLM "SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings" "WarnOnIntranet" = 0 HKLM "SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings" "ProxyEnable" = 1 HKLM "SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings" "MigrateProxy" = 1 HKLM "SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings" "ProxyServer" = <server name> HKLM "SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings" "ProxyOverride" = <list of exceptions>then this setting can be saved as external .reg file youcan aolso add it to the ISo .
