Silent installs
Hi!
I made a new image with some silent installers:
vcredist 2005, 2008, 2010, 2012 and 2013 both x64 and x86.
I also had a silent for .net 4.5.1.
It installed only vcredist x64
No vcredist x86 or .net
I use v1.5.3.20
Any Ideas?
/Falo
Hi,
this works perfectly for me (32 and 64 Bit) for the Visual Runtimes.
START /WAIT "Visual C++ 2005 SP1 Runtime x86" "%~dp0vcredist2005SP1_x86.exe" /q:aSTART /WAIT "Visual C++ 2005 SP1 Runtime x64" "%~dp0vcredist2005SP1_x64.exe" /q:aSTART /WAIT "Visual C++ 2008 SP1 Runtime x86" "%~dp0vcredist2008SP1_x86.exe" /q:aSTART /WAIT "Visual C++ 2008 SP1 Runtime x64" "%~dp0vcredist2008SP1_x64.exe" /q:aSTART /WAIT "Visual C++ 2010 SP1 Runtime x86" "%~dp0vcredist2010SP1_x86.exe" /passive /norestartSTART /WAIT "Visual C++ 2010 SP1 Runtime x86" "%~dp0vcredist2010SP1_x64.exe" /passive /norestartSTART /WAIT "Visual C++ 2012 Runtime x86" "%~dp0vcredist2012_x86.exe" /passive /norestartSTART /WAIT "Visual C++ 2012 Runtime x64" "%~dp0vcredist2012_x64.exe" /passive /norestart
Edited by Shodan2000
I used these switches:
vcredist_x64 2005.exe /q
vcredist_x86 2005.exe /q
vcredist_x64 2008.exe /q
vcredist_x86 2008.exe /q
vcredist_x64 2010.exe /q
vcredist_x86 2010.exe /q
vcredist_x64 2012.exe /quiet /norestart
vcredist_x86 2012.exe /quiet /norestart
vcredist_x64 2013.exe /quiet /norestart
vcredist_x86 2013.exe /quiet /norestart
.net 4.5 /passive /norestart
But only the x64 redists got installed not x86 or .net
The files is in WinToolkit_Apps folder as they should.
/Falo
Edited by Falo
