September 9, 201511 yr I am updating an existing image to update with new versions of Silent Installer programs. One of the "always Install" (Notepad Replacer) programs is not run, despite the fact that it appears in the Integrated list at the end of the run and is in the WinToolkit_apps directory. When I run AIO, I check the "Delete Silent Installers" in options. Is this correct? Suggestions?WTK version 1.5.3.21WTK Installer vrsion 1.5.3.18Run on Win7_x64 systemAIO select Windows (7) Home Premium
September 10, 201511 yr Author I have attached the RegEdit, which shows that there is an entry for Notepad Replacer.
October 28, 201511 yr Author After much trial-and-error, I have solved the problem by using 8.3 notation for the parameter (/NOTEPAD=C:\Progra~2\Notepa~1\Notepa~1.exe instead of /notepad="C:\Program Files (x86)\Notepad++\notepad++.exe") . There is apparently a problem with double-quote symbols, at least in the silent installer parameters.
