Posted April 4, 20178 yr Hi. Im trying to use your great Tool together with E2B. Now when E2B boots after installing Windows 7, the Silent Installers that I integrated with Wintoolkit won't start. Im trying to find the solution myself, what would help me is to know from where and when the installers are called. I noticed that the install.ini from an image I made (without E2B) doesn't have entries in the install.ini File under .\sources but still installs the programs I integrated, so the install.ini file doesnt seem to be involved? I see a registry entry that calls wintoolkitrunonce.exe , but I can't seem to find that or any kind of configuration file that tells it what to start with what switches? Maybe you can guide me in the right direction so I can solve the problem myself ... Thanks so much! Fantastic work with Wintoolkit
