October 8, 20196 yr When i try to download Access 2016 the download will start, but after 1-2 minutes it will stop/stall. Other downloads from office 2016 like home and student and other office components as well Thank you!
October 8, 20196 yr Not the problem with the ISO Downloader. Check your internet connection and if still not working, try a download manager like IDM.
October 8, 20196 yr Author 2 hours ago, SnowBall said: Not the problem with the ISO Downloader. Check your internet connection and if still not working, try a download manager like IDM. MY connection is fine: https://www.speedtest.net/result/8656566677. 219/30-40. Everything works fine expect the downloads of several office products. also tested it with a other network same result. so i tried it also with the IDM. Still same result Edited October 8, 20196 yr by justme
October 8, 20196 yr Are you downloading this: https://officecdn.microsoft.com/db/492350F6-3A01-4F97-B9C0-C7C6DDF67D60/media/nl-NL/AccessRetail.img
October 9, 20196 yr Author 9 hours ago, SnowBall said: Are you downloading this: https://officecdn.microsoft.com/db/492350F6-3A01-4F97-B9C0-C7C6DDF67D60/media/nl-NL/AccessRetail.img https://officecdn.microsoft.com/db/492350F6-3A01-4F97-B9C0-C7C6DDF67D60/media/nl-NL/AccessRetail.img Same as you, and now i test it and it works. Maybe something was wrong with the cdn server of Microsoft. case closed And thanks for the help!
