Entity Framework Beta 2 & the 1st Entity Framework Tools CTP Released!
Beta 2 of the Entity Framework includes many great improvements and added features since the last release of the June CTP, including:
Events to customize code generation
Abstract types in EDM models
Complex types
<Using> support in metadata files
Entity key serialization
Increased persistence ignorance in entity data classes
Improved connection management in ObjectContext
Improved DataBinding usability
Metadata annotations
Better support for span over LINQ to Entities queries
Improvements to LINQ queries: additional canonical functions and automatic mapping from CLR functions to server functions
A new event for extensibility of SaveChanges
Usability and consistency improvements
Polymorphic results from stored procedures
Along side the Entity Framework Beta 2, we are releasing the ADO.NET Entity Framework Tools Preview. The main purpose of this, the first release of the Entity Framework Tools (CTP1), is to get feedback from you.
Specifically in this release, we have focused on "database first" scenarios and worked hard on the core designer and mapping user experience. Here's a list of features in this release:
Entity Designer
Generate a model from a database (via wizard) and display it on the designer surface
Edit conceptual model properties (namespace, alias, etc.)
Control visual aspects of the design surface (layout) and persist changes
Add, Delete, and Edit Entities; Scalar properties; Associations; and Inheritance
Automatic set management
Automatic Navigation property management
Error reporting
Validate model and mappings using Entity Framework Runtime
Entity Mapping
View the mapping for a C-Side Entity or Association
Rename or delete C-Side objects without worrying about mapping
Map an EntityType to multiple tables
Apply multiple conditions to a table mapping
Map associations
Automatic generation of conditions and referential constraints on associations
TPH: Map an Entity hierarchy to a single table
TPT: Map an Entity hierarchy to multiple tables
Entity Model Browser
Understand and visualize the model in a tree hierarchy
Visually relate shapes on the designer surface with hierarchy in model
Visual Studio Integration
Support for C# and VB in multiple project types: ASP.NET Web site, ASP.NET Web Application Project, Console, WinForms, and Library
Project system integration: item template for .edmx file, model generation wizard, EdmxDeploy.exe, and Entity Framework validation on build
Support for multiple Visual Studio editions: Express, Standard, Pro, and VSTS.
Download Entity Framework Beta 2 | Entity Framework Tools (CTP1) | Samples
Source: Microsoft Dowload Center
Edited by cro-man
