Widget Maker
Build your own Yahoo Widgets with this XML coding helper.
Want to build widgets? Once you have some level of expertise, you can get help with the specifics of XML widget coding via Harry Whitfield's Widget Maker. Nothing substitutes for programming expertise when it comes to crafting the handy mini-programs that run through Yahoo's Widgets. You'll find excellent XML and JavaScript tutorials online.
A form-filling interface is provided to assist in the generation of the XML script of a Widget. Users still have to create images and write the JavaScript code needed to provide the Widget's functionality.
http://www.widgetgallery.com/view.php?widget=35942" target="_blank">Homepage
