VystalVivid
Do you have the boring Windows 2000 or XP, and wish it looked like Windows Vista? Or are you stuck with the Windows Home Vista Basic Version without the Aero feature? Maybe you just want to give your existing system a finishing touch... If so, you need the new VystalVivid.
VystalVivid gives your borders the Aero Glass effect just by one click.
No installation! Just download and run!
Homepage
Check out the screenshots
Download
