October 20, 200718 yr Hi Wincert forum.I had used Sidebar installer before and it works great, but I found out that the regular installer was discontinued, but there
October 20, 200718 yr Look in Add or Remove Programs, there is a uninstall entry for the Windows Sidebar
October 20, 200718 yr Author Thanks, but Which components do I need to install to get it work??The Same as the one with VaioXP??
October 20, 200718 yr Its all in the FAQ... IE7, KB940541 (wireless lan) and Alky for Applications (by Rafael and Zoronax)Theres even a Video
October 20, 200718 yr Author Look in Add or Remove Programs, there is a uninstall entry for the Windows SidebarThanks, but I looked at the FAQ........But I don
October 20, 200718 yr Yes you have but not KB940541 because its not for Swedish but install this instead KB918997
October 20, 200718 yr Author Yes you have but not KB940541 because its not for Swedish but install this instead KB918997Ok, Rick, thanks alot........... :thumbsup_anim:
