November 19, 200718 yr Free utility to copy files faster in Windows- Handy tool to organize files. Allows you to copy files from different locations and paste them all together.- Copy paths of multiple files in a single click.- Launch Windows Command Prompt from any folder.- Plugs into most of the popular file managers (including Windows Explorer).With Piky Basket, you can reduce repetitive tasks when copying/moving files and folders in Windows. Piky Basket allows you to select files/folders in to a "basket" from different locations. Once you are done selecting, you can paste them all at once to the target folders. It also allows you to selectively paste the files to the target folder.Piky Basket is integrated with Windows Explorer. You do not have to run Piky Basket as a separate program. It can be accessed from the menu which appears by right clicking on any files/folders in Windows Explorer.Piky Basket is a replacement for Windows file copy/paste operationPiky Basket can save lot of time when organizing files on your hard drivePiky Basket can be very useful when copying same set of files to different locationsPiky Basket can be used when taking backup of files and folders from different locationsPiky Basket can be used when burning a CD which requires copying of files and folders from different locationand more.....
