November 22, 200717 yr wondering if there any out or will be coming soon.cheersbtw this site rocks as much as ryanvm's/msfn. :thumbsup_anim:
November 22, 200717 yr Rick just got his copy so his update pack should be finished soon, nLite patches the files just fine, hell nLite overall works fine on it.And all our addons will be fine for it.P.S. Thanks for the nod I think this site rox too.
November 22, 200717 yr Yeah, Rick has a SP3 update pack. Just a heads up, I have tried to switch over to SP3 but unfortunately I had a sound card issue and could not fix it. There are a lot of people with the same issue, specially with HD systems. I have not yet found a fix for it.
November 22, 200717 yr You have to re-install a certain hotfix.Let me try to find where I remembered that from.
November 22, 200717 yr All addons and nLite patches work with SP3P.S. my SP3 updatepack is tiny, only small updates (nothing to be proud about )But when SP3 is released I will try to make an "All In One" updatepack with Hotfixes, IE7 and WMP11 (currently just practicing)
November 22, 200717 yr Author WindowsXP_KB835221_x86_ENU.exe is the file you need to fix audio got it from thehotfixshare.i keep forgetting about nlites patching since i mainly use rvmintegrator.and yeah i tried ricks update pack, on the 1st service pack. it was good.. i think 1-2 files though need to be updated now. also pack says 1.04 and when integrating comes up as 1.03??not really bothered with wmp11 & ie7 since i use mpc and firefox portable. give us a yell(pm) when your done rick, cheers.
November 23, 200717 yr Author btw does anyone know if they've fixed the cd key bug from the first beta service pack.where if you used you key that sp3 may invalidate it.
