Polar MultiClipboard
Polar MultiClipboard is handy and very simple to use. It sits in the system tray, captures items as they are copied to the Windows Clipboard, and then when you need an item, you can call it up with a single keystroke or mouse click.
Polar MultiClipboard is a tool to be used each and every day, no matter which application are you working with. You simply must have it! We @ Polar can't live without it. It literally saves our lives!
Limitations of standard clipboard features
The clipboard is a temporary storage area where Windows stores text or graphics you cut or copied. The original Windows clipboard is great for cutting and pasting a single item at a time, but if you want to save the items for later use ...
... you need Polar MultiClipboard!
If needed, Polar MultiClipboard saves all the clips you have ever copied, although you can also limit the number of clips to be saved. Furthermore, MultiClipboard enables you to save clipboards permanently and to assign a shortcut key to each of them.
At the same time, Polar MultiClipboard enables you to use clipboards from your network neighbours, as well as giving them access to yours, but only if and when you want it. The options are: Not Shared; Share to all users; Share to selected users.
Using multiclipboard
To save something to your clipboard simply copy or cut it by pressing CTRL+C or CTRL+X or right click on the mouse and select Copy/Cut. Polar MultiClipboard then automatically stores it.
An item can be retrieved easily by selecting it from the multicliboard list and pasting it by pressing Enter or more conveniently by using HotKeys which can insert the clip straight into an application.
Polar MultiClipboard can be your best friend - by customizing its wide range of options, you can make it behave just the way you want it to!
When and where to use it?
There are various situations where you'll find Polar MultiClipboard a time and energy saving tool. Not only does it enable you to use an unlimited number of copied items, but you can also save your clips into a permanent clipboard and whenever you need that text (a block of text perhaps) you can simply paste it with just one keystroke.
Besides that, how many times have you wanted to send your colleague a picture, or a block of text (s)he needs for his/her work. Using Polar MultiClipboard makes it so easy and super quick - just press CTRL+C and your network neighbours can use your clips!
In the Register tab of the software, fill in the following info.
Serial number: 2576566008
Please note! Technical support is not available for this free product.
Edited by cro-man
