Publisher's Description
SDS (Shutdown Scheduler) is a utility allowing to automate shutting the system down or closing specified applications. It is also able to break a modem connection, restart or hibernate the system or even put it to standby mode.
Many options make the program highly customizable for your particular needs, for example, condition under which the program will perform specified action:
SDS (Shutdown Scheduler) 2.42
at given time,
after specified period elapses,
after the computer is idle for specified amount of time,
when specified application is closed.
You can even combine the conditions and whichever occurs first, triggers the action. Despite the number of options, the program is really easy to use
Shutter 2.90
Shutter is a multifunctional shutdown utility, which has a user friendly and easy-to-use interface and supports many different Events and Actions.
Shutdown Events: Countdown, On Time, Winamp Stops, Low CPU Usage, User Inactive, Battery Low;
Shutdown Actions: Shutdown, Reboot, LogOff, Lock Workstation, Sleep, Hibernate, Monitor Turn Off, Alarm;
Also it is able to play a custom sound and/or run a program of your choice, in addition to the simple shutdown message.
MXDown 1.0
MXDown is an excellent utility designed to help you either shutdown, hibernate, suspend or restart your computer when you need it to and it is unattended. You may also have MXDown log you off when you need to and you are not around the computer.
Specifically, MXDown functions in one of three ways: By Date/Time trigger, by attaching to a process and waiting for the process to exit or by attaching to a process and waiting for the process to complete its tasks though not necessarily exiting.
This range of functionality allows you to have MXDown perform any of its available commands on your computer either on a specific time or when a task is complete. Let
Thanks you
