Any way do completely remove Microsoft Edge from ISO?
I'm trying to make a custom ISO, but I cannot get rid of Microsoft Edge. When the GUI window appears and my custom software starts to install after OOBE, Edge Update service is also launched as I can see in the Task Manager - and I cannot remove it beforehand since it is not in the Services list in AIO Integrator. I also did remove it in Components Removal tool. What am I doing wrong? The build in question is Windows 10 Pro x64 22H2, Toolkit version 1.7.0.15
Also I have trouble adding a custom wallpaper: I tried both the tab in AIO Integrator and a custom .bat file in SFX section setting the registry key - none of it worked. I mean, the reg key is changed, but the wallpaper is not updated. Any way to fix it?
Edited by Alex654
  • Alex654 changed the title to Any way do completely remove Microsoft Edge from ISO?
