The smallest free tool for taking screenshots of different size. Just open Snapa, resize it's window to fit the area you want to save, and press "Save" button.
* SnapaShot is the easiest and quickest way to capture the screen!
* You don't need to install it, just download and use Snapa anywhere
* SnapaShot is only 68Kb (only one file) and pure net 2.0
* You can cut variable sized snapshots from any webpages, photos and online videos
* SnapaShot save snaps in 5 graphic formats
* Snapa Light best screen capture is free
System requirements
You should have net 2.0 installed (most XP and Vista already have it)
Choose Snapa screen capture software instead of windows "print screen" button. Ideal for image cropping without any Photoshop and etc..
Homepage & Download
very thanks Cro-Man is very good software
  • 1 year later...
Please sign in to comment
Sign In Now
