May 2, 200818 yr ClutterBuster is an application that will hold most of the shortcuts, to software, that you have on your desktop.Each button can be set by right clicking and selecting the .exe file you want to associate with it. The button will show the image, from the icon found in the .exe file. If it has no icon, the button will show blank.When you close ClutterBuster it will store all of the info in an .ini file.Once you set it, you can then delete all the clutter from your desktop and use ClutterBuster to access your programs instead.Homepage & Download
