May 22, 200817 yr I need some help....i found a file and i need to "copy the sysdm file in your> WINDOWS\system32 Folder".It
May 22, 200817 yr you can replace it with the sysdm.cp_ file within the I386 folder of your XP.For that, use this command to compress your file then replace it with the other one.makecab sysdm.cpl
