June 6, 200817 yr hello alli have unfortunately not success to create an inf for my first addon i have learn the great tuto video of our super modo RICK but when i try FCGBA i got lot of errorshere is my inf :[Version]Signature="$Windows NT$"[Optional Components]Task Killer[DefaultInstall]AddReg =Task Killer.AddRegCopyFiles =Task Killer.Files,lang.FilesprofileItems=Task Killer.AddShortcut,UNINSTALL.AddShortcut,Desktop.AddShortcut,QuickLaunch.AddShortcut[Task Killer]OptionDesc ="Registry Entries"Tip ="kill process appz"Modes =0,1,2,3AddReg =Task Killer.AddRegCopyFiles =Task Killer.Files,lang.FilesprofileItems=Task Killer.AddShortcut,UNINSTALL.AddShortcut,Desktop.AddShortcut,QuickLaunch.AddShortcut[DestinationDirs]Task Killer.Files=16422,Task Killerlang.Files =16422,Task Killer\lang[SourceDisksNames.x86]1="Windows XP CD-Rom","Task Killer.cab",,"i386"[SourceDisksFiles]cat.lng=1chi.lng=1chs.lng=1cht.lng=1csy.lng=1deu.lng=1eng.lng=1file_id.diz=1fra.lng=1history.txt=1hun.lng=1license.txt=1pol.lng=1ptg.lng=1readme.htm=1rus.lng=1spa.lng=1taskkiller.chm=1TaskKiller.exe=1taskkiller.ini=1ukr.lng=1uninstall.exe=1[Task Killer.Files] readme.htmtaskkiller.chmtaskkiller.iniTaskKiller.exeuninstall.exefile_id.dizhistory.txtlicense.txt[lang.Files]fra.lnghun.lngpol.lngptg.lngrus.lngspa.lngukr.lngcat.lngchi.lngchs.lngcht.lngcsy.lngdeu.lngeng.lng[Task Killer.AddShortcut]Name =Task KillerCmdLine =16422,Task Killer,TaskKiller.exeSubDir =Task KillerWorkingDir=16422,Task KillerInfoTip =kill process appz[UNINSTALL.AddShortcut]Name =uninstallCmdLine =16422,Task Killer,uninstall.exeSubDir =Task KillerWorkingDir=16422,Task KillerInfoTip =Uninstall Task Killer[readme.AddShortcut]Name =readmeCmdLine =16422,Task Killer,readme.txtSubDir =Task KillerWorkingDir=16422,Task KillerInfoTip =readme Task Killer[Desktop.AddShortcut]Name =Task Killer,0x00000008,25CmdLine =16422,Task Killer,TaskKiller.exeWorkingDir=16422,Task KillerInfoTip =kill process appz[QuickLaunch.AddShortcut]Name =Task Killer,0x00000008,26CmdLine =16422,Task Killer,TaskKiller.exeSubDir =%QUICK_L%WorkingDir=16422,Task KillerInfoTip =kill process appz[Task Killer.AddReg]; Reg2Inf v0.46 - [url="http://tinyurl.com/fgqyf"]http://tinyurl.com/fgqyf[/url]HKCU,"Software\RSD Software, Inc.\Task Killer",,0x10HKCU,"Software\RSD Software, Inc.\Task Killer","Version",0x0,"v2.30"HKCU,"Software\RSD Software, Inc.\Task Killer","InstallPath",0x0,"%16422%\Task Killer"HKCU,"Software\RSD Software, Inc.\Task Killer","Installer Language",0x0,"1036"HKLM,"%UNINSTALL%\Task Killer",,0x10HKLM,"%UNINSTALL%\Task Killer","DisplayName",0x0,"Task Killer (remove only)"HKLM,"%UNINSTALL%\Task Killer","UninstallString",0x0,"\uninstall.exe"[strings]UNINSTALL="SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall"QUICK_L ="Microsoft\Internet Explorer\Quick Launch"very thanks for help
June 6, 200817 yr From what I can see, your problem is with your "[Task Killer.Files]". You can not have spaces in the [], change it to [TaskKiller.Files] and fix the others. ([Task Killer.AddShortcut],[Task Killer.AddReg])
June 6, 200817 yr Author Very thanks LUZR4LIFE for your replyi try this and give you reportsi think you see right many thanks
June 6, 200817 yr I should have asked for the FGCBA report. LOLAlso fix "Task Killer.Files=16422,Task Killer" (TaskKiller.Files)You may also want to change.....OptionDesc ="Registry Entries"toOptionDesc ="Task Killer Addon" or alike, since this is no longer just Reg.entries. Edited June 6, 200817 yr by LUZR4LIFE
June 6, 200817 yr This is the problem, when there is a space in a path in DestinationDirs you have to use quotes[DestinationDirs]Task Killer.Files=16422,"Task Killer"lang.Files =16422,"Task Killer\lang"BTW your CAB name is too long (I also suspect your INF is also) and it has a space so this means its not 8.3 filename compliant[Version]Signature="$Windows NT$"[Optional Components]Task Killer[DefaultInstall]AddReg =Task.Killer.AddRegCopyFiles =Task.Killer.Files,lang.FilesprofileItems=Task.Killer.AddShortcut,UNINSTALL.AddShortcut,Desktop.AddShortcut,QuickLaunch.AddShortcut[Task Killer]OptionDesc ="Registry Entries"Tip ="kill process appz"Modes =0,1,2,3AddReg =Task.Killer.AddRegCopyFiles =Task.Killer.Files,lang.FilesprofileItems=Task.Killer.AddShortcut,UNINSTALL.AddShortcut,Desktop.AddShortcut,QuickLaunch.AddShortcut[DestinationDirs]Task.Killer.Files=16422,"Task Killer"lang.Files =16422,"Task Killer\lang"[SourceDisksNames.x86]1="Windows XP CD-Rom","TaskKill.cab",,"i386"[SourceDisksFiles]cat.lng=1chi.lng=1chs.lng=1cht.lng=1csy.lng=1deu.lng=1eng.lng=1file_id.diz=1fra.lng=1history.txt=1hun.lng=1license.txt=1pol.lng=1ptg.lng=1readme.htm=1rus.lng=1spa.lng=1taskkiller.chm=1TaskKiller.exe=1taskkiller.ini=1ukr.lng=1uninstall.exe=1[Task.Killer.Files]readme.htmtaskkiller.chmtaskkiller.iniTaskKiller.exeuninstall.exefile_id.dizhistory.txtlicense.txt[lang.Files]fra.lnghun.lngpol.lngptg.lngrus.lngspa.lngukr.lngcat.lngchi.lngchs.lngcht.lngcsy.lngdeu.lngeng.lng[Task.Killer.AddShortcut]Name =Task KillerCmdLine =16422,Task Killer,TaskKiller.exeSubDir =Task KillerWorkingDir=16422,Task KillerInfoTip =kill process appz[UNINSTALL.AddShortcut]Name =uninstallCmdLine =16422,Task Killer,uninstall.exeSubDir =Task KillerWorkingDir=16422,Task KillerInfoTip =Uninstall Task Killer[readme.AddShortcut]Name =readmeCmdLine =16422,Task Killer,readme.txtSubDir =Task KillerWorkingDir=16422,Task KillerInfoTip =readme Task Killer[Desktop.AddShortcut]Name =Task Killer,0x00000008,25CmdLine =16422,Task Killer,TaskKiller.exeWorkingDir=16422,Task KillerInfoTip =kill process appz[QuickLaunch.AddShortcut]Name =Task Killer,0x00000008,26CmdLine =16422,Task Killer,TaskKiller.exeSubDir =%QUICK_L%WorkingDir=16422,Task KillerInfoTip =kill process appz[Task.Killer.AddReg]; Reg2Inf v0.46 - [url="http://tinyurl.com/fgqyf"]http://tinyurl.com/fgqyf[/url]HKCU,"Software\RSD Software, Inc.\Task Killer",,0x10HKCU,"Software\RSD Software, Inc.\Task Killer","Version",0x0,"v2.30"HKCU,"Software\RSD Software, Inc.\Task Killer","InstallPath",0x0,"%16422%\Task Killer"HKCU,"Software\RSD Software, Inc.\Task Killer","Installer Language",0x0,"1036"HKLM,"%UNINSTALL%\Task Killer",,0x10HKLM,"%UNINSTALL%\Task Killer","DisplayName",0x0,"Task Killer (remove only)"HKLM,"%UNINSTALL%\Task Killer","UninstallString",0x0,"%16422%\Task Killer\uninstall.exe"[strings]UNINSTALL="SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall"QUICK_L ="Microsoft\Internet Explorer\Quick Launch"I removed some spaces from your section names, this was causing a error with FGCBA too... I also fixed your uninstall string, it did not have %16422%\etc
June 7, 200817 yr Author This is the problem, when there is a space in a path in DestinationDirs you have to use quotesBTW your CAB name is too long (I also suspect your INF is also) and it has a space so this means its not 8.3 filename compliant[Version]Signature="$Windows NT$"[Optional Components]Task Killer[DefaultInstall]AddReg =Task.Killer.AddRegCopyFiles =Task.Killer.Files,lang.FilesprofileItems=Task.Killer.AddShortcut,UNINSTALL.AddShortcut,Desktop.AddShortcut,QuickLaunch.AddShortcut[Task Killer]OptionDesc ="Registry Entries"Tip ="kill process appz"Modes =0,1,2,3AddReg =Task.Killer.AddRegCopyFiles =Task.Killer.Files,lang.FilesprofileItems=Task.Killer.AddShortcut,UNINSTALL.AddShortcut,Desktop.AddShortcut,QuickLaunch.AddShortcut[DestinationDirs]Task.Killer.Files=16422,"Task Killer"lang.Files =16422,"Task Killer\lang"[SourceDisksNames.x86]1="Windows XP CD-Rom","TaskKill.cab",,"i386"[SourceDisksFiles]cat.lng=1chi.lng=1chs.lng=1cht.lng=1csy.lng=1deu.lng=1eng.lng=1file_id.diz=1fra.lng=1history.txt=1hun.lng=1license.txt=1pol.lng=1ptg.lng=1readme.htm=1rus.lng=1spa.lng=1taskkiller.chm=1TaskKiller.exe=1taskkiller.ini=1ukr.lng=1uninstall.exe=1[Task.Killer.Files]readme.htmtaskkiller.chmtaskkiller.iniTaskKiller.exeuninstall.exefile_id.dizhistory.txtlicense.txt[lang.Files]fra.lnghun.lngpol.lngptg.lngrus.lngspa.lngukr.lngcat.lngchi.lngchs.lngcht.lngcsy.lngdeu.lngeng.lng[Task.Killer.AddShortcut]Name =Task KillerCmdLine =16422,Task Killer,TaskKiller.exeSubDir =Task KillerWorkingDir=16422,Task KillerInfoTip =kill process appz[UNINSTALL.AddShortcut]Name =uninstallCmdLine =16422,Task Killer,uninstall.exeSubDir =Task KillerWorkingDir=16422,Task KillerInfoTip =Uninstall Task Killer[readme.AddShortcut]Name =readmeCmdLine =16422,Task Killer,readme.txtSubDir =Task KillerWorkingDir=16422,Task KillerInfoTip =readme Task Killer[Desktop.AddShortcut]Name =Task Killer,0x00000008,25CmdLine =16422,Task Killer,TaskKiller.exeWorkingDir=16422,Task KillerInfoTip =kill process appz[QuickLaunch.AddShortcut]Name =Task Killer,0x00000008,26CmdLine =16422,Task Killer,TaskKiller.exeSubDir =%QUICK_L%WorkingDir=16422,Task KillerInfoTip =kill process appz[Task.Killer.AddReg]; Reg2Inf v0.46 - [url="http://tinyurl.com/fgqyf"]http://tinyurl.com/fgqyf[/url]HKCU,"Software\RSD Software, Inc.\Task Killer",,0x10HKCU,"Software\RSD Software, Inc.\Task Killer","Version",0x0,"v2.30"HKCU,"Software\RSD Software, Inc.\Task Killer","InstallPath",0x0,"%16422%\Task Killer"HKCU,"Software\RSD Software, Inc.\Task Killer","Installer Language",0x0,"1036"HKLM,"%UNINSTALL%\Task Killer",,0x10HKLM,"%UNINSTALL%\Task Killer","DisplayName",0x0,"Task Killer (remove only)"HKLM,"%UNINSTALL%\Task Killer","UninstallString",0x0,"%16422%\Task Killer\uninstall.exe"[strings]UNINSTALL="SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall"QUICK_L ="Microsoft\Internet Explorer\Quick Launch"I removed some spaces from your section names, this was causing a error with FGCBA too... I also fixed your uninstall string, it did not have %16422%\etcvery very many thanks LUZR4LIFE and ricktendo64 you are greatnow i understand origin of my errors fixed with any errors many thanks i release it in section : WPI, nLite and RVM Addons
June 7, 200817 yr NP, I have been there myself. Feel free to post any issues. If you can for any others do the screenshot of the FGCBA, that makes things quicker for us to help.
