[Addon] TASK KILLER 2.30
thx looks cool i will try it and if any prob it will be reported
in the ini
[readme.AddShortcut]
Name =readme
CmdLine =16422,Task Killer,readme.txt
SubDir =Task Killer
WorkingDir=16422,Task Killer
InfoTip =readme Task Killer
readme.txt <<<< this is not in the program folder
it`s readme.htm
in the ini
Name =readme
SubDir =Task Killer
it`s readme.htm
Yes , now fixed you can redownload it
very thanks for your look DARK _KNIGHT
hmmm while i was looking for something i found that the main language is Fran
