March 4, 20251 yr We’re happy to announce the release of Opera 128 Stable!This update includes a Chromium upgrade to version 144.0.7559.173 and a broad set of stability and quality fixes, with a strong focus on Enhanced Split Screen reliability (restoring, workspaces/tab islands interactions, and crash fixes).Key highlights:Enhanced Split ScreenEnhanced Split Screen has graduated from Early Bird and is now fully available to all users. This revamp introduces significant updates to split screen including:Support of up to 4 tabs: Split screen supports up to four active tabs simultaneously within a single Split Screen instance instead of only 2.Customisable layout: In addition to the standard vertical side-by-side view, users can now create a horizontal layout or a grid layout when handling three or four tabs. It is still fully resizable via draggable separators across all layouts.Unified address bar: To reduce visual overhead and clutter. Experience has been consolidated to feature a single address bar. Active web domains appear as domain chips on the address bar. Users can interact with these domain chips to expand the full URL, rearrange, or remove a tab from split screen.State & Workspace Logic: Alongside the rollout, this update improves Split Screen behavior in everyday scenarios such as restoring from Recently Closed, working across workspaces, and handling edge cases that previously caused crashes.Sharing Point in Early BirdYou can now easily share opera with friends and family. Sharing Point is now enabled in the Early Bird. Click the share (gift) icon on the bottom left of the sidebar to easily share a link and a customisable message to download Opera.Stability improvementsSeveral crash fixes across sync, Split Screen, sidebar overlay, and some page/video-related areas.Known issues:The Recently Closed menu may generate a duplicate entry after closing a Split Screen in a second window. We’re working on a fix.For a complete rundown, take a look at the changelog.Silent installation Silent installation https://www.mediafire.com/file/kzvzgppvxqhr6vv/Opera+128.0.5807.66+AIO+Silent+Install.7z/filehttps://transfer.it/t/Uw14JB1TQLxZ Opera 95.0.4635.80 Win 7 AIO Silent Install https://www.mediafire.com/file/kbaf93g4l5vx69b/Opera+95.0.4635.80+Win+7+AIO+Silent+Install.7z/filehttps://mir.cr/0WGSZLTW Edited 3 hours ago3 hr by T3rM1nat0Rr3
March 14, 2025Mar 14 Author Changes in Opera One 117.0.5408.93:DNA-118548 After pressing Ctrl+F / Cmd+F on the Start Page (SP), the focus should be on the search barDNA-121183 Add ‘transparent UI’ parameter to Vibe logicDNA-121184 Allow to specify extra palette for window background in Vibe logicDNA-121232 Enable Slack, Discord and Bluesky flag on all streamsDNA-121237 Crash at opera::SidebarExpandViewEmbedder::PositionDNA-121322 [Opera Translate] [Redesign] Expired #translator flagDNA-121381 [Mac] Network Installer crashed after run it with –v=1DNA-121385 Remove “passkey” stringDNA-121387 [Mac] Network Installer does not always apply tracking data override
March 21, 2025Mar 21 Author Changes in Opera One 117.0.5408.142:DNA-121314 Use the extra palette color to paint the frameDNA-121321 Refactor ColorSet structDNA-121444 Crash at opera::VibesServiceImpl::VibesServiceImplDNA-121477 Add unit tests for ColorSetDNA-121488 [ASAN] ColorSetTest.DefaultConstructor failsDNA-121498 [Mac] Netinstaller fails when owner of Opera.app is different user
April 5, 2025Apr 5 Author Changes in Opera One 117.0.5408.197:DNA-120637 Refreshing the page in discord logs out user
April 17, 2025Apr 17 Author Changes in Opera 118.0.5461.41 Stable:CHR-9973 Update Chromium on desktop-stable-133-5461 to 133.0.6943.143DNA-12079 won’t activate the drop down menu buttons when clicked onDNA-115136 Extract common components and stylesDNA-117250 Make split screen drop area flash on hoverDNA-117684 Crash at opera::component_based::SplitScreenViewDelegate::OnDragUpdatedDNA-118000 Cache weather widget resultsDNA-118306 Wallpaper dissappears on Start Page when opening DevToolsDNA-118397 Crash at opera::component_based::ComponentTabContainerLayout::CalculateProposedLayoutDNA-118548 After pressing Ctrl+F / Cmd+F on the Start Page (SP), the focus should be on the search barDNA-119313 Visual bug after creating split screen and destroying tab islandDNA-119620 Crash at opera::component_based::ComponentTabBar::OnTabGroupClosedDNA-119724 Crash at TabStripModel::MoveWebContentsAtDNA-119767 [Video conferencing popup] Tab with opera://video-conference-detached is unexpectedly restored after browser restart when video conf popup is openDNA-119785 Icons are missing from opera://settingsDNA-119875 Crash at TabGroupModel::GetTabGroupDNA-119881 [Web UI] Format TypeScript codebase and fix linting errorsDNA-119882 [Styleguide] Format TypeScript resources and fix linting errorsDNA-119927 No spacing maintained between the text and popup’s border in opera://extensionsDNA-119943 [Toolbar Miniplayer][Detached miniplayer] Toolbar and detached miniplayer displayed at the same timeDNA-119962 Icons are less visible on opera://settings in Themes sectionDNA-119975 [My Flow] Two entries are visible when sending a fileDNA-120009 Remove expired feature base::kFeatureComponentBasedContextMenuDNA-120191 [Dcheck] Crash at opera::vpnpro::VpnProUpdaterImpl::GetComponentVersionDNA-120326 Crash at TabStripModel::AddToNewGroupDNA-120338 Show option to close tab in split screen on hoverDNA-120345 Playwright tests failed on dcheck buildDNA-120353 Enable noImplicitAny in TypeScript configurationDNA-120406 [Settings] Wrong UA translations for sidebar shortcuts settingsDNA-120431 Allow moving split screen tabs to another workspace as a split screenDNA-120483 DevTools settings display Chrome UIDNA-120497 Encoding delay visible in WebRTC callsDNA-120498 [Win] Shortcut for theme switching looks bad on windowsDNA-120503 Software H.264 encoder not available if hardware acceleration is disabled completelyDNA-120516 Optimise code adding, removing and updating VibesDNA-120517 Do not use tab group in TabStripModel, maintain split group view from SplitScreenModelDNA-120519 Implement session save / restore functionality for Split ScreenDNA-120523 [Toolbar miniplayer] When switching player services with pinned player Option to pin player to toolbar is availableDNA-120534 WebRtcH264BrowserTest.CanSetupH264VideoCall fail with PlatformSoftwareH264EncoderInGpu enabledDNA-120542 [Toolbar Miniplayer] It is not possible to pin the Miniplayer to the toolbar in private window.DNA-120547 [Toolbar miniplayer] Button to pin miniplayer to toolbar does not match design in light modeDNA-120554 Add import bookmark from Arc browserDNA-120567 [Toolbar miniplayer] Add hover effect to buttons in toolbar miniplayerDNA-120569 Crash at opera::BrowserWindowImpl::AddWidgetToTrackedDNA-120582 Bump major version to 118.0DNA-120585 “🡨 Error” button malfunction @ chrome://extensions errors pageDNA-120588 Layout of extensions-section is brokenDNA-120596 Discord icon is not visible in light modeDNA-120602 Crash at opera::WorkspacesTest::VerifyNextTabCyclingOrderDNA-120610 Upgrade Midsommar from built-in to hosted themeDNA-120611 Upgrade Aurora from built-in to hosted themeDNA-120613 Crash when creating new tab from split screen with active infobarDNA-120632 Crash at TabStripModel::IsTabPinnedDNA-120637 Refreshing the page in discord logs out userDNA-120639 Remake Themes section in Easy setup ReactDNA-120640 Remake Start Page section in Easy setup in ReactDNA-120641 Remake AI Services section in Easy setup in ReactDNA-120642 Remake Layout section in Easy setup in ReactDNA-120648 Translations for Opera 117DNA-120649 Improve TypeScript tooling and code qualityDNA-120655 [Toolbar miniplayer][Detached miniplayer] Miniplayer remains visible after refreshing player panelDNA-120656 [Linux] Crash at opera::MainMenu::RunMenuDNA-120660 [Split screen] Content of active tab does not fit when creating split screen via context menuDNA-120661 navigator.geolocation.getCurrentPosition() does not work in extension popupDNA-120664 Multiple tests from parent: WebRtcH264BrowserTest fail on goth.DNA-120666 WebRTC falls back from H.264 to VP8 on scaling attemptDNA-120669 Disable BackgroundResourceFetchDNA-120670 Workspaces mix up tabs and bookmarks are opened in the wrong workspaces.DNA-120671 Crash at NavigationNotificationObserver::TryFinalizeObserverDNA-120672 Crash at views::BubbleDialogDelegate::SetAnchorViewDNA-120673 [Bookmarks] Open folder icon not visible in opera://bookmarks in dark modeDNA-120677 Setup React-based internal page for Easy FilesDNA-120678 extensions-section should stick to leftDNA-120679 Create empty web-based popup for Easy FilesDNA-120681 Create web API for retrieving Easy Files items and metadataDNA-120682 Create initial layout of Easy Files popupDNA-120683 [Issue back] Sometimes onboarding is blank and uselessDNA-120684 Implement selecting one fileDNA-120685 Implement canceling the popupDNA-120687 Implement opening system file chooserDNA-120688 Allow selecting multiple filesDNA-120689 Implement selecting an imageDNA-120691 Wrong space between mini player and sidebarDNA-120695 Remove initial_background_color from WebContents::CreateParamsDNA-120699 Crash at PrefService::SetUserPrefValueDNA-120718 [RateMe] Typo in Ukrainian translation of negative feedback popupDNA-120720 Crash at opera::component_based::SplitScreenPageView::GetDropAreaBoundsInScreenDNA-120721 Crash at opera::VideoConferencePopoutService::OnDataAvailableDNA-120725 Parent menu’s item is invisible when expandedDNA-120739 [Task manager] Red background in Opera Task managerDNA-120744 [Win] Weather widget location is not set correctly by prefsDNA-120755 Rename Web UI dependencies base directoryDNA-120756 Crash at opera::SidebarExpandViewEmbedder::OnResizedDNA-120760 Add possibility to hide device on synced tabs pageDNA-120770 Update Web UI dependenciesDNA-120791 Import from GX is not availableDNA-120796 Can not select checkbox dont-show-again on Start Page in Private WindowDNA-120802 Implement disconnector on hovering of Split Screen tabsDNA-120803 Do not show disconnector on inactive Split Screen tabs below minimum widthDNA-120805 Move overlay widget out from FileSelectListenerProxyDNA-120814 Create public feature flag #split-screen-disconnectorDNA-120815 Create feature flag #split-screen-toolbarDNA-120816 Test profiles Main and High with #platform-software-h264-encoder-in-gpuDNA-120818 Crash when creating split screen by drag&drop with active infobarDNA-120819 Miniplayer disappears on desktop when reopening the player from sidebarDNA-120820 The Google icon in the search box is pixelatedDNA-120823 Snippets are not handled properlyDNA-120847 Enable BackgroundLoaderDNA-120848 Add ‘x’ button to close/dismiss translate popupDNA-120849 Dismissing popup adds language to never translate from listDNA-120860 [Web UI] Format CSS codebase and fix linting errorsDNA-120861 Tweak Stylelint rules for CSS filesDNA-120865 [Easy Files] Popup and overlay not adjusting to the page which requested the popupDNA-120867 [Easy files] Overlay corners are not roundedDNA-120873 Set two strings as translatable=falseDNA-120881 Update uninstall survey looks (first screen)DNA-120882 Submit new uninstall survey valuesDNA-120883 Create “What features cause you trouble?” survey stepDNA-120884 Create “Please tell us more about your reasons for uninstall” screenDNA-120887 Update Discord iconDNA-120889 The color picker cannot be selected and cannot be used to pick a custom color in Google applications.DNA-120894 [Win] The checkbox has the wrong color and is not visible (a black checkmark in a blue box).DNA-120898 Split screen group lost after switching workspace and backDNA-120915 [Win] When clicking on the tab strip, the tab island expands one of its tabsDNA-120921 “This tab was snoozed to save memory” appears for no reasonDNA-120926 [Start Page] Remove legacy Start Page resourcesDNA-120944 Crash when dragging tab to tab island with split screen insideDNA-120945 [Speed Dials] SDs background color issue when changing themesDNA-120969 Crash at opera::continue_on::shopping::ContinueShoppingBrowserTestBase::WaitUntilOffersAvailableDNA-120971 WebUI is shown when no Easy Files items availableDNA-120972 Crash at TabDesktopMediaList::RefreshDNA-120973 Use generated types for APIDNA-120975 Make opera://easy-files in tab work for developmentDNA-120977 Turn on flag #split-screen-disconnector on developerDNA-120978 Crash at opera::BrowserWindowImpl::GetWebViewBoundsInScreenDNA-120982 Increase size of the miniplayerDNA-120983 Add progress bar to MiniplayerDNA-120984 Replace ‘…’ button with ‘pin to toolbar’ buttonDNA-120985 Add blur to Miniplayer background (album cover)DNA-120987 Do not show album cover on the toolbar miniplayerDNA-120988 Show artist and track name in miniplayer on the toolbar when not hoveredDNA-121002 Add possibility to use mediapipe::TextEmbedderDNA-121017 Update TypeScript to version 5.7.3DNA-121021 The Easy Files popup gets hidden beneath the overlay after the Snapshot window in the sidebar app is closed or hiddenDNA-121025 Ensure type safety for API listener callsDNA-121026 Disallow implicit “any” type in Sidebar setup filesDNA-121027 Background color of the Easy Files popup does not match the mockupDNA-121028 The wallpaper section should be hidden when the shader theme is setDNA-121029 Remake Lucid Mode section in Easy setup in ReactDNA-121030 Images appear in a small square in tiles, not filling the entire tileDNA-121031 The Easy Files popup doesn’t fill its entire width with tilesDNA-121032 The “Show all files” label should be in a different color and centeredDNA-121033 File path is displayed instead of the file name on the Easy Files popupDNA-121035 For the sidebar, the tiles are currently displayed in just 1 rowDNA-121036 Rate the feature popup appears in the wrong place, and closes the Easy Files popupDNA-121046 Display small thumbnail of the cover photo on the leftDNA-121049 Discord icon has additional ‘shadow’DNA-121053 If the file is too large in width or height, it becomes distorted in the tileDNA-121055 Button displaying the number of items selected has the wrong background colorDNA-121057 Create API definition generation scriptDNA-121059 [Web Codecs] Software H.264 encoding broken if hardware encoding not availableDNA-121060 Crash at extensions::TabsRemoveFunction::RemoveTabDNA-121061 Add emdd_main, emdd_main_ver column to history urls tableDNA-121070 CLONE – Update uninstall survey looks (first screen)DNA-121094 Missing a frame around Easy setup windowDNA-121097 Crash at opera::easy_files::EasyFilesView::SelectFilesDNA-121122 Easy Files is not hidden/closed when lost focus with feeback popup visibleDNA-121123 Easy files is not closed when the user closes the snapshot windowDNA-121124 Release Metamorphic and Interstellar on beta/stable streamDNA-121131 After closing the page by pressing the home button, the address remains in the address barDNA-121133 Crash at opera::VibesServiceImpl::OnVibeUpdatedDNA-121134 Enable #easier-files on developer streamDNA-121135 When the slide transitions, the slide is not fully keyboard-navigable and requires mouse interaction to enable keyboard support.DNA-121139 (Re)enable browser tests on buildbot for Windows and macOSDNA-121146 Unify handling global variablesDNA-121148 The maximum spacing between tiles should be 32pxDNA-121149 Enable opera_feature_pre_install_extension_with_additional_configDNA-121155 [Win] Crash at opera::ToolbarView::LayoutDNA-121161 Disallow explicit “any” type in StyleguideDNA-121167 Show uninstall answers in random orderDNA-121183 Add ‘transparent UI’ parameter to Vibe logicDNA-121184 Allow to specify extra palette for window background in Vibe logicDNA-121191 Split screen is not closed after browser restartDNA-121193 Re-layout section header and tilesDNA-121194 Refactor importing sidebar_setup dependenciesDNA-121195 Adjust some fonts on internal pagesDNA-121201 Convert Add Button into a TileDNA-121207 FedEx tracking fails to retrieve shipment informationDNA-121210 After enabling tab scrolling, the tab bar narrows on both the left and right sidesDNA-121211 MediaFoundationSoftwareVideoEncoder cannot be used with 854×480 framesDNA-121215 Crash on exit when there is a split screenDNA-121220 The shading beneath the tile in the popup needs to be more intense to improve visibilityDNA-121224 Incorrect spacing between the popup and the sidebarDNA-121227 Change order of themes in theme galleryDNA-121230 Update TypeScript configurationDNA-121232 Enable Slack, Discord and Bluesky flag on all streamsDNA-121236 Crash at opera::easy_files::EasyFilesUIController::OnClipboardItemReadyDNA-121237 Crash at opera::SidebarExpandViewEmbedder::PositionDNA-121238 Crash at opera::WebPageSidebarItemContentBase::VisibilityChangedDNA-121256 Update tests for fonts and colors after DNA-121195DNA-121260 Disable background music during Google Meet callDNA-121268 Enable new uninstall survey on Developer streamDNA-121286 Enable #split-screen-close-tab on all streamsDNA-121287 Enable #split-screen-disconnector on all streamsDNA-121288 Enable #easier-files on all streamsDNA-121290 Enable #miniplayer-redesign-2 on developer streamDNA-121314 Use the extra palette color to paint the frameDNA-121318 The artist and track name in the miniplayer on the toolbar are cut off.DNA-121319 The track artist and track name in the miniplayer on the toolbar is not visible.DNA-121320 When the miniplayer in the toolbar is hovered over, the miniplayer buttons (previous, play, stop, next) are not visible in light mode.DNA-121321 Refactor ColorSet structDNA-121322 [Opera Translate] [Redesign] Expired #translator flagDNA-121323 Only icon is visible when dragging Speed DialsDNA-121328 operaaccount reacts tests not run on buildbotDNA-121330 React operaaccount tests failDNA-121332 Skip react tests on buildbotDNA-121333 Reenable react tests on buildbotDNA-121336 opera://crashes cannot be reachedDNA-121338 Translations for Opera 118DNA-121340 Blank video track produced on MediaRecorder sample site with software H.264 enoderDNA-121353 Promote 118.0 to betaDNA-121355 [Win|Lin] Lack of close button in detached mini-playerDNA-121357 [Mac] Permission dialog breaks Easy Files panelDNA-121378 The Miniplayer’s background in the toolbar is wrong.DNA-121381 [Mac] Network Installer crashed after run it with –v=1DNA-121385 Remove “passkey” stringDNA-121387 [Mac] Network Installer does not always apply tracking data overrideDNA-121392 translator flag expired in 116.0DNA-121409 Crash in media::CdmAdapter::GetInterfaceVersion()DNA-121413 [Toolbar miniplayer] Control buttons are not visible in private windowDNA-121414 The mouse cursor should take the form of a ‘hand’ cursor, also indicating the pin to toolbar icon despite the text ‘pin to the toolbar’DNA-121433 Extend operaBrowserPrivate to expose consent_flow.option.usage_personalized_contentDNA-121444 Crash at opera::VibesServiceImpl::VibesServiceImplDNA-121447 Playwright tests fail on debug buildsDNA-121456 Add to Opera modal does not fit on the screenDNA-121458 [Win] The Miniplayer popup has overly sharp cornersDNA-121459 The font is too large and the artist’s name has wrong colorDNA-121460 The Miniplayer buttons (play, stop, next, previous) are too smallDNA-121462 The progress bar in Miniplayer is too thickDNA-121470 [Toolbar miniplayer] Album cover not displayed in new browser windowDNA-121474 [Toolbar miniplayer] Song title and artist font does not match the designDNA-121477 Add unit tests for ColorSetDNA-121479 [Toolbar Miniplayer] Toolbar miniplayer does not move smoothly when expanding/collapsing extensions sectionDNA-121484 [Toolbar miniplayer] Cover art have too rounded cornerDNA-121498 [Mac] Netinstaller fails when owner of Opera.app is different userDNA-121499 Feedback icon not visible on start pageDNA-121504 [Win] Address bar dropdown becomes emptyDNA-121547 [Win] Remove making browser default from installerDNA-121560 Extension updates which requires manual confirmation do not workDNA-121566 Text in player toolbar shouldn’t rotateDNA-121578 Use product instead of flavor in desktop/infra_build.pyDNA-121582 Crash at extensions::TabsQueryFunction::RunDNA-121583 [MAC] Backport CHR bugfix 401059730 to O133 and O132DNA-121620 Incorrect toggle button background colorDNA-121725 Add menu to Easy Files to give feedback or turn off featureDNA-121769 The Miniplayer popup has overly sharp cornersDNA-121792 [Easy files] Three-dot menu button should be verticalDNA-121817 [Toolbar miniplayer] Gap between address bar and miniplayer is too smallDNA-121818 [Toolbar miniplayer] Hover effect on buttons should be the same as hover effect on address bar iconsDNA-121819 Uninstaller – change default buttonDNA-121820 Remove additional confirmation popup when uninstallingDNA-121833 Promote 118 to stableDNA-121836 Create separate section for Easy Files settingsDNA-121850 Enable #miniplayer-in-toolbar on all streamsDNA-121851 Enable #miniplayer-redesign-2 on all streamsDNA-121866 Inhouse translations for text in Easy Files context menuDNA-121881 Crash at tabs::UnpinnedTabCollection::AddTabRecursiveDNA-121891 kEnableAdblockerTrackers switch doesnt work
May 16, 2025May 16 Author Changes in Opera 118.0.5461.104:DNA-121912 [Miniplayer][MacOS] Detached mini-player doesn’t keep its position when moving browser windowDNA-121929 [Mac] X button is cut on the right side caused by ‘pin to toolbar’ buttonDNA-121949 [Mac][Miniplayer] Detached mini-player moves automatically to the right corner of a screen each time window is restored from maximized stateDNA-121994 Crash at base::ObserverList::RemoveObserverDNA-122012 Crash at opera::ComponentTabCyclerView::HighlightContentsDNA-122043 Converting different currencies into RUB, BYN, HRK, IDR doesn’t workDNA-122053 Text not visible when hovering over options in padlock popup
June 12, 2025Jun 12 Author 119.0.5497.88 – 2025-06-11 blog postDNA-122663 Close tab islands cannot be clicked if “Show tabs from the same domain in tooltip” is disabled119.0.5497.70 – 2025-06-04 blog postDNA-120753 Crash at opera::BrowserWindowCocoa::GetBoundsDNA-122106 Add error code and message to setError crashlogDNA-122203 Bookmark folders are no longer visible in “O” menuDNA-122149 Free vpn location is brokenDNA-122230 Missing flag icon in settings119.0.5497.56 – 2025-05-28 blog postDNA-120753 Crash at opera::BrowserWindowCocoa::GetBoundsDNA-122291 [MacOS] Disable the ‘Developer Tools’ option in the macOS toolbar when tabs are opened in split screen mode.DNA-122361 Shader has crashedDNA-122402 Enable #easy-setup-react on all streamsDNA-122409 [Clear browsing data on exit] Update the style for dark theme tooltipsDNA-122535 Crash at opera::TabHoverCardTabArtContainerView::OnTabArtButtonClickedDNA-122576 Live background loaded on GPU process crash even if not visible119.0.5497.38 – 2025-05-19 blog postDNA-122123 [Clear browsing data on exit] Options remain checked if previously selected after sync is enabledDNA-122275 Add tooltip to “On exit” part in settingsDNA-122357 [Win] Scrollbar uses outdated designDNA-122370 [O119 only] Remove DumpWithoutCrashing related to DNA-121917DNA-122377 In-house translations for on-exit tooltipDNA-122401 DumpWithoutCrashing at sql::(anonymous namespace)::RecordOpenDatabaseFailureReason(const class std::__Cr::basic_string& const, sql::(anonymous namespace)::OpenDatabaseFailedReason)DNA-122411 Backport fix for CVE-2025-4664
July 15, 2025Jul 15 Author Changes in Opera One 120.0.5543.61:DNA-119134 Crash at views::ViewAXPlatformNodeDelegate::FireNativeEventDNA-122014 [VPN Pro] Add VPN Pro section to chrome://opera-diagnosticsDNA-122111 [Mac] DumpWithoutCrashing causes browser restart on closeDNA-122222 [Split screen] Active tab refreshes instead of current tabDNA-122251 [Easy Files] Transparent glitch appears with some file types in popupDNA-122347 Background music resumes after toggling mic/camera in Google MeetDNA-122569 Gmail video popup disappears and Meet disconnects when switching tabs or clicking redirect buttonDNA-122583 [Win][VPN Pro] VPN disconnecting when another instance of browser is installedDNA-122601 Report client version in vpnpro diagnosticsDNA-122695 VPN section not available in opera settings on first runDNA-122764 [Split screen] Popup arrow is pinned to easy setup button instead of the password managerDNA-122849 The popup windows for ‘Accounts saved for this website’ and the credentials view are too wideDNA-122853 Support multiple static wallpapers in a single themeDNA-122883 [SD] Tile names are not visible in folder when a custom wallpaper is usedDNA-122959 Refactor tab automutingDNA-123026 Crash when clicking manage passwords button in address bar when “Sign in” credentials API popup is displayedDNA-123031 [Opera Translate] Opera Translate popup does not open in split screen tabsDNA-123038 Crash at -[OperaCrApplication validateMenuItem:]DNA-123057 USB netinstaller is not startingDNA-123086 Crash at BrowserLiveTabContext::GetSplitScreenIdForTabDNA-123089 [Opera Translate] “How does it work?” link leads to incorrect page
August 1, 2025Aug 1 Author Changes in Opera One 120.0.5543.128:DNA-123083 Theme Preview UI bug – multiple static wallpapers in a single themeDNA-123208 Crash at PasswordBubbleViewBase::ShowBubbleDNA-123266 Password popup not appearing in popup windowDNA-123274 The page at http://console.cloud.google.com/ crashes regardless of whether the user interacts with it or leaves it idle
August 16, 2025Aug 16 Author 120.0.5543.161 – 2025-08-07 blog postDNA-122677 [MAC] Unable to log in using TouchID passkey on MacDNA-122773 Crash at translate::ContentTranslateDriver::~ContentTranslateDriverDNA-123418 Investigate GPU process memory usage
August 29, 2025Aug 29 Author Changes in Opera One 121.0.5600.38:CHR-10080 Update Chromium on desktop-stable-137-5600 to 137.0.7151.122DNA-112270 “Delete suggestion” (x) button stays focused after suggestion is deletedDNA-115865 [Google MEET] The detached window disappears after dragging the tab to another window or move to another workspaceDNA-116619 After exit the youtube fullscreen mode, a black side bar appears on the left side of the screenDNA-118424 [Mac] Crash at opera::popup_protection::PopupProtectionServiceImpl::OnOpenedDNA-118890 Crash at opera::RegisterPathProviderDNA-119134 Crash at views::ViewAXPlatformNodeDelegate::FireNativeEventDNA-119230 Timeout in VideoPictureInPictureWindowControllerBrowserTest.VolumeSliderDNA-120162 Crash at opera::MainMenu::FillOMenuHeaderDNA-120459 [Split screen] Page content flickering when the width of the elements changes.DNA-120753 Crash at opera::BrowserWindowCocoa::GetBoundsDNA-121103 [Tab Island Split Screen] Not possible to create tab island with already existing split screenDNA-121264 [Light theme] Text and icons in popups hardly visible on hoverDNA-121406 [Intro] Update Messenger icon to new versionDNA-121824 [Dark Mode] Inactive toggles are not clearly visible in default colorDNA-121859 [Easy Files] Missing icons next to options in the menuDNA-121884 Add missing video popout testDNA-121970 Low WebRTC video quality with software Media Foundation encoderDNA-122014 [VPN Pro] Add VPN Pro section to chrome://opera-diagnosticsDNA-122111 [Mac] DumpWithoutCrashing causes browser restart on closeDNA-122203 Bookmark folders are no longer visible in “O” menuDNA-122218 [Split screen toolbar] Not all available icons are visible on hover until address bar is clickedDNA-122222 [Split screen] Active tab refreshes instead of current tabDNA-122251 [Easy Files] Transparent glitch appears with some file types in popupDNA-122283 Fields to fill in are not visible in light modes in opera://settings/DNA-122330 Missing shadow effect on Sidebar Setup panelDNA-122331 Sidebar Setup does not start from the top after reopeningDNA-122347 Background music resumes after toggling mic/camera in Google MeetDNA-122348 [Tab Island Split Screen] After dragging split screen into collapsed tab island, icon that shows that there are more tabs in island disapearsDNA-122360 VideoPictureInPictureWindowControllerBrowserTest.ControlsVisibility fails on LinuxDNA-122361 Shader has crashedDNA-122444 Add accessibility title for password manager popupDNA-122488 Crash at opera::component_based::ComponentTabView::OnMouseDraggedDNA-122493 [WebRTC] Software H.264 encoder initialization failure with odd frame dimensionsDNA-122499 [Password Management] Save-password popup displays dark mode image in light modeDNA-122500 [Password Management] Save-password popup image lacks shadowDNA-122501 [Password Management] Incorrect styling for Password Manager linkDNA-122502 Use named export for React stylesDNA-122506 Update component pages manifests to version 3DNA-122512 [Password Management] Password is shown as a clear text by system accessibilityDNA-122513 [Password Management] Font size in password-manager page is bigger than in settingsDNA-122531 Bump major version to 121DNA-122540 Translations for Opera 120DNA-122553 [Win][VPN Pro] Download subscription after enabling #vpn-pro-v4-support flagDNA-122555 [Password Management] Password update prompt is shown as sliding toolbar (old style)DNA-122558 “+” button shifts position after cancelled split screenDNA-122561 [Password Management] Manage Passwords icon is not shown in address bar when in split screen modeDNA-122562 [Password Management] Save password popup is incorrectly anchored in split screen modeDNA-122569 Gmail video popup disappears and Meet disconnects when switching tabs or clicking redirect buttonDNA-122576 Live background loaded on GPU process crash even if not visibleDNA-122583 [Win][VPN Pro] VPN disconnecting when another instance of browser is installedDNA-122587 Auto-PiP not working due to inability to check URL for safetyDNA-122588 Change search box size and categories position on scrollDNA-122589 Change structure of components and make sidebar stickyDNA-122603 Private mode badge color should be invertedDNA-122607 Make labels in themes localizableDNA-122608 Test AutoPictureInPictureWithVideoPlaybackBrowserTest.DoesAutopip_TopFrameAndSubframeDomainsAllowed of type browser test failed on goth with status failDNA-122621 After closing PiP, player in the tab stops playingDNA-122628 [O120] Crash at performance_manager::mechanism::PageDiscarder::DiscardPageNodesDNA-122629 Block auto-PiP if user closes PiP windowDNA-122632 Crash at opera::ThemesService::ThemeDataProvider::GetResourceIdDNA-122635 Backport 0-day fix for CVE-2025-5419 and chromium issue 420637585DNA-122641 The “Make Opera default browser” button doesn’t automatically change in Easy Setup after make browser as a defaultDNA-122659 startpage opening animation is not disabledDNA-122665 Tab island tooltip has incorrect designDNA-122673 ‘Save’ button doesn’t work in opera://settings/syncSetup to save created passphraseDNA-122675 Opera unpins from taskbar after updateDNA-122677 [MAC] Unable to log in using TouchID passkey on MacDNA-122688 Dragging tab island with split screen outside of tab strip crashesDNA-122695 VPN section not available in opera settings on first runDNA-122714 Crash at TabStripModel::SetSelectionFromModelDNA-122715 Crash at media::ATAudioFormatReader::ChooseFormatDNA-122723 ‘Accounts saved for this website’ popup has a chrome designDNA-122730 Password popup design do not match the mockupDNA-122734 Replace background of ‘banner’ on the VPN badge popup UIDNA-122742 [macOS] Increase MinimumSystemVersion to 11DNA-122745 The tooltip of the password manager icon has an incorrect label when hovering over itDNA-122749 Crash in AddressBarControllerImpl::OnActiveTabChanged() on non-developer channelsDNA-122764 [Split screen] Popup arrow is pinned to easy setup button instead of the password managerDNA-122765 Can’t close the popup by clicking the password manager icon in the address barDNA-122772 Crash at ManagePasswordsUIController::GetManagePasswordsButtonViewDNA-122773 Crash at translate::ContentTranslateDriver::~ContentTranslateDriverDNA-122774 Tab Island tabs dropdown not visible when “Show tabs from the same domain in tab tooltip” is disabledDNA-122778 Enable #password-management-popup on all streamsDNA-122780 [password-management-popup=off] Passwords badge not shown until user clicks in the address barDNA-122786 Allow manual re-sending of discarded crashes in opera://crashes/ pageDNA-122791 The button corners are not rounded enoughDNA-122795 Password popup header does not match the mockupDNA-122797 Crash at TabStripModel::SetSelectionFromModelDNA-122826 Crash loop when trying to launch Opera –with-feature:pinboard=offDNA-122829 [Linux] Crash at settings::DefaultBrowserHandler::HandleDefaultBrowserChangeDNA-122843 O-Menu becomes unresponsive when sidebar is set to auto-hide and then disabledDNA-122848 Tests that WaitForBrowserToClose() time outDNA-122849 The popup windows for ‘Accounts saved for this website’ and the credentials view are too wideDNA-122850 Missing tooltip over buttons on the ‘web page credentials’ popupDNA-122851 Missing hover effectDNA-122852 On the ‘Accounts saved for this website’ popup, the whole row should be clickable not only an arrowDNA-122853 Support multiple static wallpapers in a single themeDNA-122854 Investigate backwards compatibility for multiple wallpaper themesDNA-122862 Crash at opera::popup_protection::PopupProtectionServiceImpl::CloseActivePopupsDNA-122864 “Copy password” button should not be visible in save password popupDNA-122883 [SD] Tile names are not visible in folder when a custom wallpaper is usedDNA-122920 Checkboxes are invisible in Sidebar SetupDNA-122928 Hide universal skip button when video is finishedDNA-122940 Installer crashes while trying to enter the options screen twice before feature overrides are downloadedDNA-122955 Active emoji is not selected in tab tooltipDNA-122957 [MediaRecorder] Software H.264 encoder initialization failure with odd frame dimensionsDNA-122959 Refactor tab automutingDNA-122962 SessionRestoreTest.RestoredTabsHaveDelegate fails in GXDNA-122967 Improper navigation button enabled status on split screen creation (non-start page case)DNA-122968 Crash at PasswordBubbleViewBase::ShowBubbleDNA-122984 Enable #translator on all streams for Opera OneDNA-122991 Add rate me button on opera://bookmarks pageDNA-123026 Crash when clicking manage passwords button in address bar when “Sign in” credentials API popup is displayedDNA-123029 [Color themes] When an animated color theme is selected, a start page wallpaper can be chosen in Easy SetupDNA-123031 [Opera Translate] Opera Translate popup does not open in split screen tabsDNA-123038 Crash at -[OperaCrApplication validateMenuItem:]DNA-123057 USB netinstaller is not startingDNA-123063 Crash on closing the 1st tab from tooltip of a collapsed islandDNA-123064 Crash at opera::BrowserWindowSkin::GetColorProviderForWebContentsDNA-123075 Hover effect for address bar icons should match address bar hover styleDNA-123083 Theme Preview UI bug – multiple static wallpapers in a single themeDNA-123084 [Import][Edge][MacOS] Import data from Edge doesn’t workDNA-123086 Crash at BrowserLiveTabContext::GetSplitScreenIdForTabDNA-123088 Crash at chrome::BrowserCommandController::LoadingStateChangedDNA-123089 [Opera Translate] “How does it work?” link leads to incorrect pageDNA-123100 Translate popup is shown each time page is being autotranslatedDNA-123111 Chromium on Windows fails to compileDNA-123119 Sidebar messanger carousel not workingDNA-123123 Crash when trying to save file using window.showSaveFilePickerDNA-123124 Not possible to open feedback dialog on sidebar panelsDNA-123150 Crash at media::MediaFoundationSoftwareVideoEncoder::CopyInputSampleBufferFromGpuDNA-123161 [Tab Tooltip] Improve mouse detection over Tab Island HandleDNA-123175 ‘Show tab emoji’ setting not visible in opera:settingsDNA-123176 Span next to ‘Learn more’ link not visibleDNA-123178 Transient “zoom in” effect with software H.264 encodingDNA-123188 [Tab Tooltip] Hovering over collapsed Tab Island shows Tab Tooltip for a tab instead of Tab IslandDNA-123190 [Tab Island] Clicking on a collapsed Tab Island activates tab from Tab IslandDNA-123208 Crash at PasswordBubbleViewBase::ShowBubbleDNA-123211 [Win] Enable web-platform-testsDNA-123246 DCHECK on start when tutorials sidebar item is enabledDNA-123266 Password popup not appearing in popup windowDNA-123274 The page at http://console.cloud.google.com/ crashes regardless of whether the user interacts with it or leaves it idleDNA-123300 Installer fails to install for both current user and all usersDNA-123303 Promote 121 to betaDNA-123308 Crash at views::DesktopWindowTreeHostWin::PreHandleMSGDNA-123316 Failing TestSearchInRecentlyClosed.testRecentlyClosedDNA-123339 Linux ARM fails to compileDNA-123351 [Mac] The browser window cannot be moved using the sidebarDNA-123418 Investigate GPU process memory usageDNA-123424 Crash at opera::SidebarItemContentViewDockerView::GetContentInsetsDNA-123440 RTCVideoEncoder tries to use SharedImage-backed frames with software encoderDNA-123485 Add missing attribute to translation files for “ca,ta,te”DNA-123496 Plural form translation fixDNA-123534 Promote 121 to stableRNA-195 Crash at opera::VideoPopoutDetachController::OnTabStripModelChangedRNA-204 Button visibility broken in Lucid ModeRNA-225 Tabs don’t change their positions correctly and the browser window doesn’t refresh after minimizing and maximizing itRNA-226 Player text and pics are dragable and highlightableRNA-257 Blacklisted extension notification is not fully shownRNA-332 Split screen group in tab island is destroyed after moving island to new windowRNA-360 Tab tooltip blocks address bar input after opening new tabRNA-374 Crash at opera::ComponentTabBar::CreateSplitScreenGroupRNA-380 Crash at opera::PinboardControllerImpl::ShouldShowRNA-481 Crash at opera::ComponentTabBar::ReloadTabViewsForCurrentModelRNA-503 Failure to close Opera via the ‘X’ button
September 20, 2025Sep 20 Author Changes in Opera One 122.0.5643.51:DNA-123583 Frame in Opera closing dialog is missingDNA-123590 Addressbar blinks each time when character added or removedRNA-478 Close (x) button is barely visible in video popupChanges in Opera One 122.0.5643.24:RNA-369 Dark theme selects light theme wallpaperRNA-537 [History refresh] Center the icon in headerRNA-595 [History refresh] Text on buttons in action bar is cut off at the bottomRNA-605 New tab button “+” missing backgroundRNA-610 Add Open full history view button in sidebar panelRNA-670 [History refresh] Left panel in date picker updates wrongly when month is chosen on the right panelRNA-733 [Mac] Tab tooltip hides when moving mouse horizontally over tabs on tab barRNA-752 [History refresh] Not possible to select items from dropdown menus in date picker
October 10, 2025Oct 10 Author Changes in Opera One 122.0.5643.142:DNA-123706 Crash at chrome::ShowSettingsSubPageInTabbedBrowserRNA-705 [History refresh] Search input field has no max input limit and shifts page layoutRNA-860 [History refresh] Date picker displays dates with wrong weekday mappingRNA-862 The previews do not display properly when hovering over the tabRNA-906 Using autohide distrupts the window control buttons layoutRNA-972 [History] Full page name is not visible in default width of the SidepanelChanges in Opera One 122.0.5643.92:DNA-123736 Browser freezes on macOS 26 when visiting pages with input fields
November 5, 2025Nov 5 Author Changes in Opera One 123.0 Build 5669.23:CHR-10100 Update Chromium on master to 139.0.7258.156DNA-120341 Crash at opera::oauth2::DeviceNameServiceImpl::HasDeviceNameChangedDNA-121219 Crash at crashpad::(anonymous namespace)::HandleAbortSignalDNA-121828 [E-]AC-3 media unit tests fail on Windows 24H2DNA-122983 Crash at TabStripModel::IsTabLockedDNA-123306 [Win] Search from popup shown over selected text doesn’t work in full screen modeDNA-123490 Crash at settings::AddLocalizedStringsDNA-123513 DCHECK in label.cc when showing tab hover cardDNA-123532 Remove gx_media_playerDNA-123539 Missing dark theme on opera:pinboardsDNA-123541 Extension removal tests failDNA-123551 Outdated Teams call URL patternDNA-123583 Frame in Opera closing dialog is missingDNA-123584 Import chrome translationsDNA-123586 [Windows] SnapTest.NavigatingAwayDuringSnap fails on nightly buildsDNA-123590 Addressbar blinks each time when character added or removedDNA-123593 Crash at media_router::CastDialogView::CastDialogViewDNA-123597 Crash during detected language translateDNA-123603 Crash at ChromePageInfoDelegate::ShowSiteSettingsDNA-123604 Crash at blink::InterpolableFilter::MaybeCreateDNA-123625 Crash at media_router::MediaRouterDialogControllerViews::CreateMediaRouterDialogDNA-123630 Crash at blink::StyleEngine::EnsureEnvironmentVariablesDNA-123649 WebBluetoothPolicyTest.Block failingDNA-123650 RPM packaging does not work on linux (ubuntu 24.04)DNA-123668 Tabs page: regular workspace icon for local device is not shown properlyDNA-123701 Crash at tabs::TabModel::GetBrowserWindowInterfaceDNA-123706 Crash at chrome::ShowSettingsSubPageInTabbedBrowserDNA-123707 Crash at TabStripModel::GetIndexOfWebContentsDNA-123708 Crash at opera::EasyShareButtonControllerTabHelper::ShareDNA-123736 Browser freezes on macOS 26 when visiting pages withDNA-123746 Promote 123 to betaDNA-123787 Add “warn on quiting the Opera with multiple tabs open” to settings mapDNA-123810 [macOS] TouchID not working on WebAuthNDNA-123811 Advertised H.264 level in WebRTC is 3.2 / 5.2DNA-123868 Promote 123 to stableDNA-123870 Backport fix for Chromium bug 452296415 (V8: Out-of-bounds access in JSON.parse)DNA-123871 Backport fix for Chromium bug 447192722 to O123 – UAF in safe_browsingDNA-123875 Address bar jumps left on page reloadRNA-196 Dismissing translate popup adds detected language to Never translate from & Preferred languages listsRNA-205 Address bar and dropdown display unwanted outlineRNA-250 [History refresh] Unable to reset date filter using Navigate to optionsRNA-258 Display info about selected option to import opened tabs on browser tileRNA-297 Tab island tabs displayed on hover over tabs after hovering over island handle when “Show tabs from the same domain in tab tooltip” is disabledRNA-368 After create new tab while on the split screen you can’t instantly type and need to click on the search area firstRNA-369 Dark theme selects light theme wallpaperRNA-409 [Mac] Window not restored to its position after exiting full screen after restartRNA-425 Adjust group hover popup name edit boxRNA-429 Add “remove name” buttonRNA-430 Adjust color selection elementRNA-478 Close (x) button is barely visible in video popupRNA-537 [History refresh] Center the icon in headerRNA-541 [History refresh] Text cutoff in search input when typing with spacesRNA-571 [History refresh] Navigation buttons for Yesterday and Older are disabled but appear active on scrollRNA-590 [History refresh] Last item cannot be selected when action bar is visibleRNA-595 [History refresh] Text on buttons in action bar is cut off at the bottomRNA-596 ‘Make Opera Default’ button in Easy Setup comes back after restartRNA-605 New tab button “+” missing backgroundRNA-606 [Translate improvements] Unwanted line between field and dropdownRNA-607 [Mac][History refresh] Sidebar panel stays open after opening history page in a new tabRNA-610 Add Open full history view button in sidebar panelRNA-612 Remove navigate to filter from History in sidebar panelRNA-621 Opera close popup appears after dragging out all tabs from second and subsequent workspacesRNA-667 [History refresh] No message shown when history is emptyRNA-670 [History refresh] Left panel in date picker updates wrongly when month is chosen on the right panelRNA-698 [History refresh] Recent years in dropdown should appear firstRNA-699 [History refresh] Previously selected date range disappears when date picker is reopenedRNA-705 [History refresh] Search input field has no max input limit and shifts page layoutRNA-706 Change usage of runtime flag color-theme to build flagRNA-713 Translations for O122RNA-725 Incorrect font weight for language names in translation popupRNA-733 [Mac] Tab tooltip hides when moving mouse horizontally over tabs on tab barRNA-735 Translation source language reverts to previously selected languageRNA-736 [History redesign] Remove opera-intro from history entriesRNA-742 Width mismatch between select input field and its dropdown list in translation popupRNA-749 White borders on highlighted item in language dropdownRNA-752 [History refresh] Not possible to select items from dropdown menus in date pickerRNA-757 Web area does not have rounded cornersRNA-758 [History refresh] Hovered URL overlaps action barRNA-817 Crash at opera::BrowserWindowImpl::OnBrowserInitializedRNA-854 Translate from context menu triggers Arabic source languageRNA-860 [History refresh] Date picker displays dates with wrong weekday mappingRNA-862 The previews do not display properly when hovering over the tabRNA-879 Add ‘Search engine on Start Page’ section to Easy SetupRNA-885 Text is not correctly displayed after updating Mac to MaC OS 26.0RNA-898 Opera video features missingRNA-902 X button is broken when trying to close opera while reloading tabsRNA-906 Using autohide distrupts the window control buttons layoutRNA-910 Picture in picture’s frame detaching with an additional lineRNA-911 Blank crash information windowRNA-913 Option menu has incorrect tooltip nameRNA-916 Search engine radio button inner circle not centeredRNA-934 Translations for O123RNA-972 [History] Full page name is not visible in default width of the SidepanelRNA-979 Clicking on traffic light buttons doesn’t workRNA-1043 Crash at libobjc.A.dylib | opera::BrowserWindowCocoa::GetBoundsRNA-1052 Crash when closing a tab island containing a split screenRNA-1054 Crash at opera::SplitWebViewContainerAnimationController::AnimateShowingRNA-1066 Installer crashes when run with the “–help” switchRNA-1322 Enable #import-open-tabs on all streams
November 18, 2025Nov 18 Author 124.0.5705.15 – 2025-11-13 blog postCHR-9416 Updating Chromium on desktop-stable-* branchesDNA-123647 Crash at opera::SidebarController::OnItemCollapsedDNA-123972 Promote 124 to stable
December 3, 2025Dec 3 Author Changes in Opera One 124.0.5705.65:DNA-124027 [Linux] Broken installation of deb on opera-stableRNA-1378 [MAC] Switch –launchopera=[0|1] is not working with network installerRNA-1591 Sonic – Theme preview is unavailable
January 16Jan 16 Author Changes in Opera One 126.0.5750.37:DNA-124238 Crash at content::ExternalSoftwareVideoAcceleratorFactories::NotifyEncoderSupportKnownDNA-124293 Crash at extensions::ProxySwitcherPrivateEventRouter::~ProxySwitcherPrivateEventRouterRNA-1785 [Mac] Tab island tooltip is dismissed without user actionRNA-1923 Use Tab Island name when creating Pinboard folder from islandRNA-1940 [Settings] Languages section in settings doesn’t workRNA-1960 [Regression] Folder icon broken in “Bookmarks” menu (O-menu)Changes in Opera One 126.0.5750.30:CHR-9416 Updating Chromium on desktop-stable-* branchesDNA-124186 Crash at DesktopBrowserWindowCapabilities::IsAttemptingToCloseBrowserRNA-1676 Crash at opera::SplitScreenModelImpl::InsertSplitScreenRNA-1839 [Mac] Investigate reflow / layout performance of Opera with more-split-screen=ONRNA-1851 Test SplitScreenWebViewContainerView reuse logic in SplitScreenMultiSplitViewRNA-1915 Enable #google-calendar-in-sidebar #gmail-in-sidebar on all streamsRNA-1916 Enable #tab-island-customization on all streamsRNA-1918 Showing tab islands with tab island name in Recently closed section in HistoryRNA-1919 Showing Tab Island name in Tab Context Menu → Move toRNA-1920 Showing Tab Island name in History system menu (macOS)RNA-1936 Crash at libsystem_platform.dylib | opera::SplitScreenViewDelegate::DropToSplitScreenChanges in Opera One 126.0.5750.18:DNA-124168 Crash at views::View::DoRemoveChildViewDNA-124201 [DevTools] Checkboxes missing in DevTools and on websitesDNA-124207 Opera claims it supports H.264 in WebRTC even if it doesn’tDNA-124231 Opera crashes when trying to install extension in private windowDNA-124253 Promote 126.0 to stableRNA-1539 Existing URL is not displayed in the address field while editing Speed DialRNA-1826 System theme option applies light mode instead of system dark modeRNA-1834 Adjust spacing of AI button and other bars in toolbarRNA-1847 Translations for O126RNA-1786 Tab tooltip appears over the tab blocking default tab actions (eg tab focusing or closing)
February 11Feb 11 Author Changes in Opera One 127.0 Build 5778.47:DNA-123737 Crash at constrained_window::CreateWebModalDialogViewsDNA-124059 Tab Capture indicator border is missingDNA-124220 Crash at opera::TabGroupView::DetachTab when creating island of pinned tabsDNA-124373 [Mac] Not possible to import Passwords from other browsers in settingsDNA-124374 Crash at syncer::SyncUserSettingsImpl::SetSelectedTypesDNA-124403 [Win] Not possible to import Passwords from other browsers in settingsDNA-124418 Crash at opera::rich_wallpapers::(anonymous namespace)::CreateBackendParamsDNA-124439 Crash loop on startup caused by restoring tabsRNA-1746 Split screen is removed from tab island when detachedRNA-1958 Pinned side panel width is not remembered per panelRNA-2014 Tab island tooltip overlaps with tab preview textRNA-2073 Translations for O127RNA-2084 [Settings][Early Bird] Relaunch button in Early bird section is not visible when Settings are opened through Early bird button from easy setupRNA-2085 [Stable 127.0][VPN] Free VPN badge not displayedRNA-2122 Slash sign is displayed on Internal PagesRNA-2138 Increase Gmail and Calendar width in the sidebarRNA-2190 [Chromium-based]History import doesn’t work
February 19Feb 19 Author 127.0.5778.76 – 2026-02-18 blog postDNA-124374 Crash at syncer::SyncUserSettingsImpl::SetSelectedTypesDNA-124472 Improve logging when autoupdater cannot determine download directoryRNA-2214 Crash when creating split screen via drag&drop while a Google Meet call is active
3 hours ago3 hr Author Opera stable has been updated to version: 128.0.5807.66Key highlights:New sidebar options (available in Early Bird):Gemini in the sidebarGoogle Translate in the sidebarYouTube in the sidebarContext menu updates: updated entries for Tab Islands and Split Screen (Group: New Tab / Create Tab Island / Create Split Screen).Sidebar settings cleanup: messenger apps in sidebar settings split into two sections.Fixed multiple crash issues, including:macOS crash when Opera is started by the netinstallerCrash when running the Opera binary from terminal without starting the browser processNetflix: addressed issues caused by the Skip button.Warn on Quit (Windows): “You have X tabs open” message missing on smaller screensInstagram in sidebar: Fixed issue that lead to panel refreshing every time you open it.Help and onboarding links: Improved Start Page and sidebar guidance so “How do I do that?” / “How does it work?” links open the correct localized content and jump to the intended section and corrected the Gemini help link destination.
